When you fail to draw the correct unlock pattern on the screen after five attempts, you will be prompted to wait for 30 seconds before you can try again. If you forgot your screen unlock pattern, tap Forgot pattern. You will be prompted to sign in using your Google Account name and password, and create a new screen unlock pattern before the Home screen displays
If u have tried too many patterens then ur phone requires G-mail and password( Generally termed as G-mail lock)E
Easiest way to un-pettern or remove g-Mail lock from any android phone is to hard reset it.
Press volume up,camera and power on keys together for few seconds....ur phone enters boot mode or download mode......now if options appear then select erase user data...(or u can select CFT calliberation). if these options do not appear then press menu....these options should appear......on selecting any of these your phone will restart and locks are removed..
If this does not work, then download ANDROID TOOL(Android Multi Tools v1.02b gsmforum) in ur PC ....connect phone in download mode/boot mode(pressing vol up, camera,power keys together) to ur pc and read phone in android tool and follow instruction for phone reset or CFT calliberation....ur phone will unlock..........
if this also doesnot work then u will have to contact a service person . he will do the job by using other software options llike volcano tool. ">
You can lock the screen of your HTC Hero screen with a draw pattern. Here's where to set the feature in the Android software.
1. From the Home screen, press Menu.
2. Tap Settings.
3. Tap Security.
4. Tap Set unlock pattern.
5. Read the info, then tap Next when ready.
6. See the pattern, then tap Next.
7. Draw the screen unlock pattern with your finger by connecting four or more dots in a row.
8. Tap Continue.
9. Draw the same pattern again.
10. Tap Confirm.
hope this helps
John
