Question about Honeywell Programmable Thermostat Heater
The transformer on my central AC/heater (luxaire model # A236A344T LH) keeps going out. There are 4 settings on the wall. Cool, off, heat and EM. Heat. The setting switches to EM. Heat each time the transformer goes out. I noticed this the first time it went out 2 weeks ago and thought nothing of it. I replaced the transformer last week. The unit ran fine for 5 days. It went out again today and the setting was on EM Heat again.
    New Friend:
My ac/heater is producing a burnt oader, what could it be??
Posted on Mar 02, 2010
  • 306 Answers
You might have some thermostat wires that are touching meaning the insulation has been broke off and getting a direct short. Check the wiring going to the outside unit and replace any wire that is in bad shape. let me know okay. Ken
Posted on Dec 11, 2009
Anonymous
SOURCE:
Hi,I have an Alfa 2001 156 cigarette lighter not working found some fuses near the battery but not one for the cigarette lighter
Fuse box in passenger compartment Alfa Romeo 156.
fuse box location.
The fuses for the main devices are housed in a control unit under the dashboard, to the left of the steering column. To gain access to them, remove the panel (A) releasing the tabs (B) in the direction of the arrow below and remove the screw (C).
fuse box layout.
1 Ignition auxiliary circuits relay 1 2 Heated rear window relay 3 Horn relay F1 (10A) RH headlamp- high beam F2 (10A) Headlamp high beam warning lamp, LH headlamp-high beam F3 (20A) Boot lid/tailgate lamp, central locking F4 (10A) Headlamp adjustment, RH headlamp-low beam F5 (30A) Electric windows(front) F6 (10A) LH stop lamp, LH tail lamp, RH licence plate lamp, RH rear fog lamp, RH side lamp F7 (10A) LH licence plate lamp, LH rear fog lamp, LH side lamp, RH stop lamp, RH tail lamp F8 (10A) LH head lamp-low beam F9 (15A) Cigarette lighter, heater/air conditioning (AC) F10 (20A) Wind screen wash/wipe system F11 (20A) Horn F12 (10A) Alarm system, anti-lock brake system (ABS)(with ESP), audio system, instrument panel, interior lamps F13 (10A) Anti-lock brake system (ABS), central locking, electric door mirrors, electric windows, glove box lamp, reversing lamps, stop lamp (high level) F14 (10A) Hazard warning lamps F15 (30A) Door mirror heater, heated rear window
Sep 13, 2017 | Alfa Romeo Cars & Trucks
How do I set my thermostat so that it doesn't keep going off and leaving me with no hot water .I have a Honeywell digital thermostat.
The problem is not your thermostat. It is the person who told you that your AC would be your sole source of hot water. The purpose of heat recovery is to ASSIST with hot water production and reduce the current used by your water heater. The only time your AC heats your water is when it is working to cool (or if it's a heat pump, cool and heat) your home. Turn your water heater back on and let your AC help keep the water hot. It's not supposed to do it alone.
Mar 19, 2011 | Honeywell Heating & Cooling
Central ac/ heater (electric)...The heater quit working in the mid of the night, only cool air is exiting the vents. Everything else seems normal except the air is not warm anymore. We need warm air,...
check batteries in thermostat? you'll need a voltage tester,either neon light or vom.check to see if breaker is tripped.throw back and forth if it looks ok.remove cover check to see if power is getting to breaker then out of breaker.The heat is turned on with a low voltage circuit. check to see if you have 24 volts coming out of transformer.if all this checks out it gets real tricky. power to heating elements is switched via switches that are back a ways amongst lots of wires.very dangerous to work on with power on.I don't recommend trying to go further.
Jan 12, 2011 | Heating & Cooling
Hiiiii..... I have samsung Thermostat AC, But i dont know how to use the warmer / heater for the same. I dont know about the model number but its one of the old AC written thermostat. Now help me out how...
Symbolsin remote: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
Jan 03, 2011 | Samsung AW1203B Air Conditioner
Luxaire AC unit control works but the ac unit will not turn on
Sounds like it could be your transformer. See if you can locate it. It should be in the air handler indoors. Check the voltage going to the transformer and check the output of the transformer. You should have around 24 vac on the output of the transformer. If you don't have voltage on the output make sure you have it on the input (120vac). If you don't have it on the input you need to find out why. If you have it on the input but don't have an output then your transformer is likely gone bad. Let me know what you find.
May 18, 2010 | Heating & Cooling
How do you wire a honeywell round mechanical thermostat
What are you trying to wire up?
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Feb 09, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
I have a coleman Evcon model AH16-0 . I am
4 Wire Termostat
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
W = White Heat
Jan 06, 2010 | Heating & Cooling
I turned off the heat on a central heat/ac system this morning to access a sump pump that is located below the furnace system. I fixed the sump pump and now the heat will not come back on. Is there a reset...
you might check the 24 volt transformer or thermostat that is where i would start try your a/c to see if it works if it does then you have a problem inside your unit
Dec 31, 2009 | Broan-NuTone 658 Central Heating System...
I am installing a Honeywell T841 onto existing RGYW wiring. The fan kicks on, but I notice the air conditioner is not running. Were one or more of these supposed to go on the W2 or B terminals? Thanks!
Need to have more numbers in model number to be sure There's about 30 T841 t'stats and some are1, 2, and 3 stage heat pump and some 1, 2, and 3stage AC.
If you have
R to transformer
G to fan relay
Y to contactor in outdoor unit
W to Gas valve
You have the thermostat wired right.
Depending on the T'stat B could be the common side of the transformer or 2nd stage heat.
W2 terminal are for 2nd stage heat
You need to put the thermostat on cool and lower the setting to bring on the cooling. Then go outside and see if you have power to the outdoor unit and 24 volts to the contactor coil.
Sep 06, 2009 | Honeywell Electronic Programmable...
Ho to turn on central AC unit? (Ruud High Efficiency)
This is typical wiring for a 4 wire thermostat
G = Green Blower relay
Y = Yellow Cool Condensing unit
W = White Heat Furnace
Apr 28, 2009 | Ruud Heating & Cooling
Heating & Cooling Logo
321 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
