Epson Stylus CX4200 All-In-One InkJet Printer Logo
Posted on Dec 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Epson CX4200 makes horrible noise when is going throught its start up, I see yellow belt moving when noise is made and then error indicator and all other lights blink. Their tech support says to bring it in and offer no advice.
Anonymous
Level 2:
New Friend:
  • Expert 61 Answers
  • Posted on Aug 29, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
61
Questions
0
Helped
6241
Points
111
Tech support is right. They are suspecting a mechanical problem.
1helpful
Ink carriage started make some horrible noises. Stopped printing. I changed to new ink. Now no ink is printing. Ink carriage just makes thumping noises. Is there a part that can be easily purchased or...
Examine the belt that powers the print head, see if it is excessively sloppy, check the head moves freely along the print head bar, if it snags, there is damage to the bar or the print head holder is worn
TBH, I'd bury it if there is any wear as replacement parts are expensive compared to a new printer
My Epson CX4200 is printing pink pictures - help!
try printing the nozzle check page.. you will be able to see which color that is missing... it should have Yellow , Megenta, Cyan and Black... if any one of the color is missing.. try performing head cleaning and after twice cleaning and still no improvement, very high possibility your print head is clogged..
3answers
I need a cx4200 printer owner's manual. I cant find where it is on the net..I need to know the steps to replace ink cartridges. Bob C.
Have you tried " Epson Stylus CX4200 manual" on Google?...
Go to:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=58605&infoType=Doc
You have all the documents there, including a User's Guide.
1helpful
I bought new cartridges for my Epson Stylus CX4200 All-in-One, but the yellow and Magenta barely print. I have run the head-cleaning program on the computer, the one with the colored lines, and it...
Use "spet" (tube only). Add flexible pipe (cut from oultet pipe of head cleaning mechanic). Connect to nozzle. Fill tube with cleaner. Move head to parking position. Do suction from outlet pipe of head cleaning. It's the safely way to clean print head manually.
Can not install to Vista. Is there an upgrade?
Go to www.epson.com and download the lastest drivers for that printer.
Epson stylus cx4200
need to download cd forthe epson cx4200
3answers
Epson stylus cx4200 all-in-one?
1. Make sure the printer is turned on.
2. Make sure the document cover is closed, then closed, then open the scanner.
(Do not open the scanner when the document cover is open).
3. Press and release the ink button. The 'On' and 'Ink' lights flash.
If one of the cartridges is low or empty the printer moves that cartridge to the 'ink out' mark. Go to step 4.
If no cartridges are low or empty the ink cartridge holder moves to the ink replacement position. Go to step 5.
4. Pree the 'ink' button again.
If more than one cartridge is empty or low the next cartridge moves to the 'ink out' mark.
Once the printer identifies all the empty or low ink cartridges the print head moves to the ink cartridge replacement position.
5. Open the cartridge cover, squeeze the tab at the back of the empty cartridge and lift it out.
6. Before you open the new cartridge package shake it four or five times and remove it from the package .
(Don't remove or tear the label on the cartridge otherwise ink will leak out) .
(Don't touch the green chip on the front of the ink cartridge - you could damage the cartridge).
7. Place the new ink cartridge into the cartridge holder and push it down till it clicks into place.
8. Replace any other cartridges that need replacing.
9. Close the ink cartridge cover and press it until it clicks into place.
10. Close the scanner.
11. Press the 'ink' button. The printer starts charging ink and the 'on' light starts flashing . This takes about a minute . When it's finished the 'on' light stops flashing and remains on and the 'ink' light goes out.
You'll see all the above, with helpful pictures, at
this Epson support page
Epson Stylus cx4200, scanning distortion
try uninstalling than re installing the scanner driver only
(add remove programs -> epson scan)
issue persists - hardware issue
2answers
Epson CX4200
I just Fixed the error of All Lights Flashing on my epson cx4200 printer.
Solution: I Totally unpluged the printer from 110 power source
then waited 3 minutes, then press the On button and let the printer run thru its normal noises during start cycle.
Originally I tried to just turn printer off with the off/on button but this did not ix the problem.
So make sure you TOTALLY disconnect the printer from the 110 AC power source.
Hope this helps.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
