Samsung LNT5265F 52 in. LCD HDTV Logo
Posted on Dec 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 52in lcd tv and when you turn it on they are small colored vertical lines going down the left hand side but after about 20 minutes the go away. What is the problem
Anonymous
Level 3:
President:
  • Samsung Master 1,779 Answers
  • Posted on Dec 10, 2009
Anonymous
Samsung Master
Level 3:
President:
Answers
1779
Questions
Helped
578648
Points
5452
I would check the LVDS cable from the main board to the t-con board and the ribbon cable from the t-con board to the LCD display for good connection. Be very careful not to damage any of these. Sometimes they become corroded.
Portion of the screen is very dark, gets better after 20 minutes
Your LCD panel has failed, it will be cheaper to get a new set. If I have helped you please sign my guest book
http://www.back2lifeelectronics.com/Guestbook.php
I have a 37" JVC LCD TV Model # T370HW02 and the left half of the picture if filled with vertical colored lines for approximately 30 minutes after the set is turned on then the picture clears up and s
The problem with your TV is the screen tabs this is where the electronics bond to the screen a technician may be able to fix it with compression pads otherwise it a new screen
4helpful
My 52ince LCD Sony Bravia TV is started showing 2 vertical lines on each side, but they go away 20 minutes after starting TV. What is wrong?
The tv board call the T-CON decoders board have problems,that why colors vertical lines are showing up in the tv LCD screen panel.The T-CON decoders board,this board sit wright at middle bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
4helpful
Red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
3helpful
3answers
Vertical lines on my 40 inch lcd mitsubishi hdtv 1080
Similar problem with an eleven and a half month old LT-40148. Approx. 1 inch vertical banding line on left side of screen on all inputs. After about two weeks, same problem on the right side of the screen.
Fortunately this occurred two weeks prior to the one year warranty expiring.
Called Mits customer service and they referred me to an authorized service center who I happened to have dealt with before.
They picked up the set. The front panel (LCD screen ) had to be replaced. Set was gone for two weeks as parts were not in stock. There was no charge. I hope this screen last more than a year.
Half my screen works
I had this, and it was just a small connection that was loose.
6helpful
2answers
Vertical colored lines on left half of screen.
I had a similar issue. Took it in and apparently i had 4 bad capacitors and after replacing those, my tv was perfect. But I think I lucked out on this one. :) try it.
36helpful
6answers
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
1helpful
2answers
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
