Question about Epson Office Equipment & Supplies
My printer and jump over pages - Epson Office Equipment & Supplies
    Genius:
  • 1,018 Answers
I do not understand your problem. Can you provide a better failure description, please?
1) Do you mean that your printer was printing say page 5 of a 15 page document and suddenly jumper to page 14 and you are missing 9 pages of the document.
2) Your document is printing page 5 and suddenly you get 5 blank pages and then the text begins printing on page 6. No data is lost but you have 5 blank pages.
Problem 1: More than likely caused by a data flow control failure.
Problem 2: Can be a myrid of things. For example, Extral Line Feed commands accidently imbedded into the datatream, worn indexing parts allowing the motor to drive the paper up more then it is supposed.
Posted on Dec 10, 2009
6ya staff
SOURCE:
Paper jumping problems
kindly set the page length in printing setting just press the pause button and go to configuration setting mode and set the parameter as per your software or print file.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 17, 2010 | Epson LX-300+ II Matrix Printer
My printer has started "jumping" in other words, at various points on the page(in stripes down the length of the page) the letters are duplicated above each other? Can you assist. I work on a new Mac...
open the cartridge cover, wipe out the ink cartridge, with a piece of paper, reinstall it, then give a print command,,,
dont forget to check the ink level
Mar 28, 2010 | Office Equipment & Supplies
My lq 2180 printer is not aligned properly.printing starts 2 to 3 inches from start of page.jump in every next page is increased by half inch.kindly guide Thanks
Dear user,
please check the paper size and the procedure is below.
open printer properties and then go to the printing preferences and then there slect there appropriate paper size according to your paper being used in printer.
hopefully it will work perfect.
Sep 03, 2009 | Epson LQ-2180 Dot Matrix Printer
PRINTER EPSON STYLUS C43SX
Did you mean paper jam?. If you have used printer for long time, or many pages printed, the paper feeder mecahnic deteoration, especially two rubber in paper feeder. You can replace paper feeder. Or you can repair the rubber by adding tape below rubber to to add thickness of rubber. I have tried and success. Good luck 4 u.
Apr 08, 2009 | Epson Stylus C43SX InkJet Printer
HP 1100 A LASER PRINTER , 3 LIGHTS ON AFTER PRINTING, THEN DID,T
This is copied from my previous response to your post:
"I had to jump in my 'time machine' for this one, but it is probably as simple as a low toner cartridge. remove it, and give it a shake, then replace it, to see if that solves the problem in the sort term. Get a replacement cartridge if it does".
Apr 04, 2009 | HP LaserJet 1100a Printer
Not printing on left side of page
The problem is that the revolving drum doesn't contact the OPC drum proberly. You have to open the left side off the machine and replace the little white gear on the shaft that drive revolving drum. The gear has "jumped"one step and the revolving drum isn't parallell to the OPC drum. I fixed my 2840 last night it takes some time but now it works perfect.
Feb 25, 2009 | HP LaserJet 2840 Printer
Ricoh CL7000 - Black lines every 4,5 or 9 pages
Sounds like the registration clutch is faulty. The knocking maybe the fuser unit jumping gears check that unit also check that the green paper holders are all in the correct place.
Thanks Jason
Jun 30, 2008 | Ricoh Aficio CL7000 Laser Printer
Will lnot print a complete page. jumps to next page
Hi , try to print preview before printer you can able to ajust the margin.save in print preview.
Feb 12, 2008 | Canon BubbleJet i560 InkJet Printer
125 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
