The very common way to start the computer on the desired drive is by pressing the ESC key after the computer reboots/restart on the keyboard.
The computer will display the all the drive connected on your PC, and you will choose the drive number where the drive that you want be the first one to boots up.
Hope this helps.
If you want to boot setup from xp pro boot disc, you have to go first to the bios/cmos setup of your system, from there check the boot order, if you find that the first boot device is your hard drive change it, make your cd/dvd rom your first boot device and second your hard drive save the setting that you have made and restart your pc, before you restart insert the installation disc, then reboot, from there it will automatically boot in the xp pro set up disc
When you restore your system back to the new factory settings, it will wipe your hard drive clean and do a fresh install of the operating system with the original factory setting.
To start this process, unplug all extra devices from your computer
(printers, external hard drives, etc.) as these can interfere with the system restore.
Starting with Windows XP, most systems with issued a system recovery disk in case of any problems with the factory installation.
Check the documentation and disks that came with your computer to determine if you have one of these system disks.
If you do have a copy of this disk, place it in your CD/DVD drive and restart your computer.
If you do NOT have a copy of this disc, skip to step 3 for further instructions.
Once you restart your computer, a screen will appear with the words.
Press Any Key to Boot From CD. Once you press a key, a screen will come up containing instructions to format your hard drive and restore the original factory settings.
Follow the on-screen prompts to finish the installation.
Once the restore is complete, remove your Recovery CD from the disk drive so that your computer does not try to boot from the CD again.
Restart your computer to complete the restore.
3. If you do not have a System Restore disk, then your computer should have a recovery partition on your hard drive, separate from the main partition of the disk.
Unplug all external devices and restart your computer.
When the loading screen comes on with the Windows logo, press Alt+F10 together five times.
This will bring up the system restore menu.
Follow the on-screen prompts to restore your computer back to the factory settings
hope this helps
Turn Off the computer, now as soon as you hit the power
button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10,
it will open the recovery console ,select full factory restore and follow on
screen instruction. (Note:this will erase all datas on the computer) or During the boot process you will see on the screen to
press a certain key to enter setup Press and hold that key during the boot up
process to enter BIOS you can load failsafe defaults or load optimized defaults
,press escape then press f10 to save to cmos to restart
hope this helps
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart hope this helps
if you still want to load another operating system
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
