So what would the problem be? i have the same problem tubes dont have life but get the sound of power up when the power button is pushed?So what would the problem be? i have the same problem tubes dont have life but get the sound of power up when the power button is pushed?
You can't post conmments that contain an email address.
According to the owner's manual page 2.7 (and this is an OLD [by HDTV standards] set), the TV can only handle input resolutions of 480p or 1080i on the composite inputs. Most HDTV programming today is 720p with some 1080i and 1080p on certain channels (like some Discovery shows about nature). It is possible that your set will not process the 720p signals being sent.
Tv has no picture or sound; will go out while watching. The picture will go into a line and sound and picture will go out; shortly after that tv will turn off. Did this last nite and I did not turn back on until this morning, it worked no problem. On for couple of hours and now it's out again. What could be problem and how do I fix myself
You may have to change the aspect ratio but doing so may change the picture quality. Your owners manual should explain how to do this. If you don't have the manual you may be able to download it from Samsung for your particular model TV.
It means you covergence setting not ok.use remote press (mute183) set covergence lines remember before you save these setting press self focus botton in remote and exit by smode
The flashing light is giving you an error code as there has been some sort of failure in the TV. The buzzing sound could be the flyback transformer. Count the number of flashes. I'm sure the code will be for the flyback.
This is a convergence problem and can easily be fixed either by resoldering the pins on the convergence ICs or by replaceing them if they prove to be defective. Can you solder? Do you feel confident in replacing these parts?
Keep us posted.
Dan
