Noritz 6.3 Gallon Residential Tankless Water Heater - N-063S Logo
Posted on Dec 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code 14 shows on the remote for a noritz tankless lpg water heater. what does it mean?
Anonymous
Level 2:
Scholar:
  • Expert 73 Answers
  • Posted on Jul 15, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
73
Questions
0
Helped
70422
Points
113
This means the thermal fuse has broken and needs replacement. The thermal fuse is a white cord which wraps around the heat exchanger. It typically breaks if the unit is excessively dirty and sooted. Before the fuse is replaced you should make sure the unit is cleaned with compressed air and descaled.
Noritz: Tankless Water Heater. I have an error code 99 on my Noritz tankless. How do l reset it please?
Remove the bird's nest in the flue.
The 10, 59, 90 and 99 error codes indicate that a Noritz heater has experienced a combustion abnormality. In most cases, it is the result of an obstruction in the heater's flue. Examine the flue to see if it is blocked by debris and clean if necessary.
How To Resolve The Seven Most Common Noritz Tankless ...
Noritz https://www.noritz.com > Blog
Nov 16, 2015 - This error code involves a breakdown in communication between two tankless water heaters using the Quick Connect Cord. It can occur when more ...
Troubleshooting Noritz Tankless Water Heaters and Error Codes
home-water-heater.com https://www.home-water-heater.com > noritz-error-co...
Error code 90 and 99 ... Action: Check for the obstructed venting, improper gas burning (flame shape and color change). Ensure the water heater gets the ...
Error Codes for a Noritz Water Heater - Waterheatertimer.org
How to clear error code 78 on a noritz tankless
For a Noritz tankless water heater, error number 78 indicates a problem with the fan motor. The instructions below will help you clear the problem number 78 on a Noritz tankless water heater:
  1. Turn off the power to the tankless water heater by either disconnecting it or switching off the circuit breaker.
  2. Verify that the fan motor is clear of any obstructions or debris that may be preventing it from operating properly.
  3. Check the fan motor is receiving power by measuring the voltage across the fan leads with a voltmeter. Verify that the electrical connections to the fan motor are secure if there is no voltage.
  4. If the fan motor is broken or not operating properly, it may need to be replaced. For further assistance with the repair or replacement of the fan motor, you can contact Noritz technical support or a certified HVAC specialist.
  5. After resolving the issue with the fan motor, switch off the power to the tankless water heater for at least 30 seconds before turning it back on. This will clear the error code and restore normal operation to the device.
  6. If you are unclear or uncomfortable with any of these processes, you should seek the aid of a certified HVAC specialist or Noritz technical support.
I have a Noritz tankless water heater (model n-132m). I am getting an error code of 71. What does that mean?
The Noritz Manual shows fixed for the following error codes:
11
21
90
99
For all other codes this is the recommendation:
Contact our sales agent if:
• Any other error code appears.
Error code 43 on 8.4 noritz
You know, either it's tankless or it's 8.4gal but it can't be both. Does that figure mean 8.4gal/minute at a certain flow rate and temperature?
Code 125 on my Noritz tankless water heater
Call noritz
(866) 766-7489
http://www.noritz.com/contact-us/
Don't buy a tankless water heater.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
What is error code 043 on NORITZ tankless heater?
There is no error 43 on a NR71. There is a 73 error code which is caused by disconnecting jumper cables while the power is on.
1helpful
What does F-76 code mean on a Noritz M-069 panel
F76 is a communication error. It usually occurs if you connect or disconnect a quick connect cable or remote control when the tankless heater is connected to electricity. (If you have a quick connect system, make sure you only have 1 remote and 1 quick connect cable.) To get rid of the code, try disconnecting electricity for 20 seconds, reconnecting electricity, and turning the remote on. If the code returns, you may need to replace your quick connect cable, remote cable, or even remote control
1helpful
Getting error code 16. what does it mean and what
a 16 error code is typically caused by scale formation. I'd recommend performing a descale on the heater.
11helpful
2answers
Noritz tankless water heater not producing hot water
I called Noritz error code 16 is a overheat problem. Noritz say's to flush your coil with vinegar or CLR.
Use a small pump to recirculate the CLR or vinegar through the system for 45 minutes and flush with fresh water. This worked for me.
Top Noritz Water Heaters Experts
Paul Carew
john h
Are you a Noritz Water Heater Expert? Answer questions, earn points and help others
