MY DVD DRIVE DOESN'T PLAY PROPERLY NOW. IT JUST HAPPENED SUDDENLY WHILST I WAS WATCHING A MOVIE.
THE SYMPTOMS ARE THAT: -
1. The pace of both the picture and sound is inaccurate and jerky.
2. Sound and picture are often out of sync.
3. Jerkiness occur repeatedly, but sometimes the movie wont continue to play at all. The drive tries to spin up, pauses, tries to spin up again ? this goes on and on for several minutes and can?t be stopped (the drive won?t eject). When it finally stops and the drive ejects the disc will be burning hot.
4. You never know if/when (and why :mad: ) the movie will stop working in the middle.
Sometimes the problems are really bad, sometimes not so. At its worst the computer won?t play a disc at all. A disc that won?t play at all one day may at least be somewhat watchable the next.
6.Also, when i try to burn movies onto cd it takes much longer than usual.
7. You cant play audio on the laptop when the dvd drive is running.
DO I NEED TO BUY A NEW DVD DRIVE OR SOMETHING CAN YOU PLEASES HELP ME
SOURCE: picture sticks, breaks up repeatedly
Change the location of the unit, this sounds like an overheating problem. It is too close to other units or is enclosed in a tight space. You may also try putting a small fan behind it to cool it down.
SOURCE: LAPTOP DVD DRIVE WONT PLAY DVDS
i have just recently updated windows and its took my drive out again, comes up with Windows cannot load the device driver for this hardware because a previous instance of the device driver is still in memory. (Code 38)
Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available.
HELP
SOURCE: Does not play any disc
Thats bad..Did you try another disc? If this happens even with a different disc. You will need to get a lens cleaner(costs about 5$) and try cleaning the lens. If it still doesn't work then you will have to replace the lens. The reason why it died suddenly is probably because the lens circuitry somehow got shorted. Try cleaning and if not.. replace.
SOURCE: wont spin dvd's anymore
You can try and clean the laser optics with a cotton swab dipped in isopropyl alcohol. Just open the DVD lid. It is usually a small glass lens ( often clear or blueish in color)
let the excess alcohol evaporate.
If that does not give more motor movement, its possible you have a defective spindle motor or drive IC
SOURCE: will play discs burned from hdd but not commercial movie type dvd
The solution is simple.I rang LG service (so called - LOL)
Asked for a fix or reset method. (Which can be done but they won't tell novices how)
Got no joy, so now I will bin it,and spend the rest of my days telling people to avoid LG.
After all the posts I have since read about the same problem on various LG models,it is obvious their product sucks,they know it does, but won't accept the responsibility.
If I stop 4 people buying their ****,that's at least $1000 they miss out on.
If the process snowballs,how much then$$ ?
It would cost me $120 just to get it to and pick it up from the repair place.
Plus parts and labour added.
Before buying an LG DVD recorder go online and check out how many dissatisfied customers there are. In short, DO NOT BUY !!
