Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Solution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
Found error in image file, Error Occurred,
error 0901, 572, 2881 The camera says found error in image file,
repair data now. When you press yes it says "Error
occurred. Please replace disc." or use ac
adapter/charger, turn off power. It won't let
you go to Disc Navigation to finalize it. While
recording video on DVD-R media the battery power
may have failed and camera shut off. When turned
on the message shown on the lcd is Found error
in image file, Error Occurred, error 0901.
The LCD screen may display a FILE ERROR message
when trying to view a still image on the Camera if the image was
rotated, modified and overwritten using editing software on a Computer.
To play images you have taken on the Camera, it is recommended that you
do not make any changes to the original image files.
It seems that the images are rotated or modified in the Computer.
