Ovens Logo
Posted on Dec 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am attempting to pre-heat oven to 400 degrees but oven heat will not raise above 100 degrees
Anonymous
Level 3:
  • GE Master 2,605 Answers
  • Posted on Dec 09, 2009
Anonymous
GE Master
Level 3:
Answers
2605
Questions
0
Helped
1119160
Points
11111
Hi, Upon reading your post I immediately thought of a bad ignitor for the oven, but I am not sure whether you have a gas oven or a conventional electric range. So...If it is gas, I'd suggest replacing the ignitor for the hot surface ignition. If it's electric the bake element may be at fault although most range's use the broil in the preheat, so it should still climb up to 400, it would just take a really long time. Maybe you can clarify if it's electric or gas and I can try to move you forward from there. Macmarkus :)
GE JTP15WD1WW Giving F3 and F5 Error Codes
possible burner tube blocked if ok check gas pressure from gas valve possible not open all the way
Feb 19, 2022 • GE Ovens
How do you reset the frigidaire wall oven?
Good Afternoon Friend,
I understand you are trying to reset your Frigidaire wall oven, model# FEB27S5A, due to it not heating above 100 degrees. I suggest resetting at your homes circuit breaker for 3-5 minutes. When you restore power, you will first need to set the clock. After setting the clock, preheat your oven. If you are still noticing that the temperatures are still not going above 100 degrees, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to not reach the desired temperatures. Hope this is helpful.
-Best regards-
WP
2answers
GE free-standing electric range Pre-heat oven temp is about 50 degrees less than what is set (i.e. set digital display to 400 and over only reaches about 350). Is there an adjustment that can be made to...
We have a new GE Range and the signal beeps at about 100 degrees below the temp which we have set . The dealer replaced the sensor and the control circuit, but there was no change.
A service tech from GE came to our house and explained that the new ovens have a bottom heating element which is covered and therefore heats the lower part of the oven more slowly; but the exposed upper element heats more rapidly and the sensor is located near the upper element. We were advised to wait for about 15-20 minutes after the beep before placing the food in the oven. Judging from the number of comments found online, this seems to be a feature of newer ranges.
SnapDoc
Temperature varies
very normal but only during pre heat / once the oven is stable tempt should be 5 to 10 deg above and below the tempt setting and if not replace the oven temp sensor located inside the oven on the back ..mm
The oven temperature isn't correct. Ovenw Won't heat up.
has the oven got a fan on it. if so then maybe fan is faulty.
if convection oven then maybe one of elements is faulty
or the thermostat is a problem
regards
richard saupe
Appliance repairman colchester
appliance repairman
Oven will not heat until you turn the heat up to 400 degrees
Your "Bake" element may not be working properly. It's the one in the bottom of the oven. Place a couple drops of vegetable oil on the bottom pan, and turn the oven on. During pre-heat, you should start to see those oil drops generate some smoke, IF the lower element is working properly. If it isn't - voila'.!! Problem is with the lower element / associated circuit.
1helpful
Set oven to pre-heat to 350; won't go above 100 degrees
could be one of 3 problems: missing 240volts and only have 120volts(one leg out)/bad element(chk for "hot-spot") pitted and discolored-it will soon break there/or the thermocouple is bad that senses oven temp
Oven Temp
After it drops temperature, how do you get it back to the desired degrees? It sounds like the thermostat isn't keeping up.
Top GE Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a GE Oven Expert? Answer questions, earn points and help others
