Question about Frigidaire 14 Cycle Tumble Action Washer
Had the same problem and fixed with ease. The problem is with the door lock. There is a secondary locking mechanism that kicks in for the final spin due to the high speed. When the secondary lock goes bad the washer will not do the final spin. The replacement part is under $40 @ AppliancePartsPros.com .
Posted on Feb 02, 2010
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
Nov 19, 2014 | Frigidaire Washing Machines
Jun 19, 2014 | Frigidaire 14 Cycle Tumble Action Washer
Nov 02, 2013 | Frigidaire GLTF2940ES Front Load Washer
Dec 21, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Feb 27, 2010 | Frigidaire ATF6000ES Front Load Washer
Nov 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Jun 24, 2009 | Kenmore 44072 Front Load Washer
873 people viewed this question
