Canon ZR100 Mini DV Digital Camcorder Logo
Posted on Dec 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No power my camcorder wont power on.
Anonymous
Level 3:
Guru:
  • Master 1,738 Answers
  • Posted on Dec 07, 2009
Anonymous
Master
Level 3:
Guru:
Answers
1738
Questions
Helped
470881
Points
4963
Your battery is bad. You can buy batteries for relative cheap. Do a internet search for your particular battery and it should bring back your battery.
Do you need a working battery to run camcorder off ac power adapter? I havent used camera in 2 years and just bought replaceable power adapter and wont charge battery or work off outlet at all..camera was...
You do not need a battery to run the camcorder off ac power supply. It is one or the other. The only time that both will be used is when you are charging the battery on the camcorder with the power off.
Hope this helps.
www.austintelstarservices.com
Disc wont finalize
Camcorder wont finalize disc on battery power, it will finalize disc with powering it by ac adapter/ charger.
How do i finalise the double sided disk so it will download onto my computer? My computer wont pick up solution disk either? I know that anithalize delete's it!...
Finalize disc in camcorder while powering it with supplied ac charger/ adapter. Camcorder has option for that.
You can not finalize disc in computer that was recorded on camcorder.
2helpful
Camcorder problem
If it is not battery fault then its charging IC or fuse damage.You can also use external charger to charge the battery
2helpful
3answers
My pv-gs180 camcorder wont power up. I have
Remove battery plug it into power (charger block) then do reset.
What does this mean c;31;23
The camcorder has detected an issue that may require a power reset.
To perform power reset:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
If the issue still persits try with different media.
Dcr dvd200e wont record
Does camcorder show good picture in playback and does not give you live view to record?
or it does not power up?
Your post is not clear about porblme with camcorder and please intimate exact model number of camera too.
PROBLEMS POWERING ON
Make sure your batteries are good. If you have new batteries and it still wont power up I would send it back to where you got it.
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
