Ovens Logo
Posted on Dec 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Advise use of self clean feature on kenmore self clean oven 30''
30'' smooth top kenmore self clean oven bought 2001-02? forget how to use self clean feature
there is a press button that says ''clean'' on the panel...do I just press it or is there more to the instructions
  • Anonymous Mar 15, 2014
    Can I use oven cleaners on Kenmore oven that has Self Clean (Flex Clean) feature?
Jim Thurston
Level 3:
  • Master 672 Answers
  • Posted on Dec 07, 2009
Jim Thurston
Master
Level 3:
Answers
672
Questions
Helped
270169
Points
2170
If there is an up and down arrow on the control panel, you need to press the clean button first and then choose clean time with the up and down arrow. Be sure to remove the racks, if left in the oven they will be blackened by the extreme heat. Clean them separately with oven cleaner. Place them on newspaper and spray them.
Did the self cleaning. Now it has a F 3 code & door will not unlock.
  • Check warranty to make sure it has expired.
  • Disconnect power for 30 seconds and see if oven will reset the electrical lock.
The following link describe for Kenmore several procedures to disengage the electrical lock securing the door.
It is unfortunate that during the self cleaning cycle the stress levels at the elevated temperature premature failure appears to occur.
How to Clear the Oven Lock Mechanism on Kenmore Stove
The F3 error is most likely the temperature sensor that protrudes into the oven near the top usually on the left. Don't be confused there can be two probes that enter the oven. One is the over temp like not to exceed type of switching device and the other is the actual sensor that maintains the temperature at the set point.
There is a procedure to replace this sensor from inside the oven. I have had only limited success doing this repair in ovens from the front. Newer ovens are equipped with a plug that is easier. In all cases ensure that the plug is pushed through away from the oven wall. In older ovens I have had to pull the built in ovens to accomplish the work from the back to ensure a good connection using wire nuts... The sensor in the second photo does not have a plug so small wire nuts that will fit through the back of the oven are used.
26060093-3hiy01xauopzuspf4owyz2yd-3-2.jpg This second link is a suggestion that the use of the self clean feature is a concern, On two occasions I have had oven problems right after using the self clean cycle.
http://www.thekitchn.com/why-you-should-almost-never-use-the-self-cleaning-function-of-your-oven-175110
Jan 19, 2016 • Ovens
Fisher and Paykel AeroTech Double - OD301 Electric Oven Oven not working after self cleaning
Ours have also stopped working (both top and bottom). Bought in 2003 so only 8 yrs old. Getting technician in to fix. Will post solution. Also whenever oven is heated up the display panel fades and is not visible (has been doing this for a couple of years)
I recently bought a home with a Kenmore Self Cleaning Ultra Bake Oven but no manual to be found. Serial # 9755994 Model 880 655 124PO. I would appreciate any information regarding this stove and how to...
Head over to the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
The inner oven glass of my self-clean oven has a small crack. Can I still use the self-clean feature?
No, that may be what cracked it in the first place...the self clean or self destruct feature will noly finish it off for you...
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
5helpful
Self cleaning oven error code FSEO
Probably a bad door lock solenoid. That is some kind of door lock problem. Trouble is they are not all the same. This training manual shows locations of model number. Perhaps if you post that I might can come up with a tech sheet and you would get a better answer. see page 4
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
I have a Kenmore Gas Oven, model # 911.30465864 and have lost the manual. I want to clean the oven, (it has self cleaning feature), but I am not sure if I can use oven cleaners in Gas Oven or not. Can...
Just use some easy off and do not use the self clean feature. Clean it the old fashioned way. Self clean ruins expensive electronics.
Feb 20, 2010 • Ovens
VDSC307-4bss how to operate self-cleaning oven
I continued a search and found a manual on line... simple process to turn on self-cleaning operation... close the door and set to "clean" ... timer on this model is automatic... runs for 3 1/2 hours.. fan continues for an additional 30 minutes ... open the door and the oven is clean. Thanks
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
