Tip & How-To about Video Game Consoles & Games
This is a very frustrating problem and there are quite a few possible causes for this failure to happen with the Xbox. You can spend hours on the internet looking for an answer to this issue.
However, thankfully there is one very simple solution that is often overlooked when this problem occurs and I am writing this tip so that anyone who has this issue can check this out as first step in resolving the problem before moving on to anything else.
On the actual cable that connects to the XBox there is a little HD switch right on the side of the connector. If this little switch is in the HD position and your TV is non HD you will end up with sound and no picture!!!
Therefore please check this cable (see picture below for exact location of the switch) to ensure that it is in the position that is correct for your TV set.
If this does not resolve your problem please work through the following steps.
1) Reset the display resolution to its default settings. To do this;
Red Ring of Death: Red Flashing XBOX 360 Lights Explained
Common Xbox 360 Red Ring Errors
The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error,
follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
