D-Link (DI-711) Router Logo
Posted on Dec 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am on hughes satelite internet and my connection failed yesterday when the cord from the back of the modem came out. It is back up and running but only directly from the modem to the tower NOT thru the d link anymore. What do I do to get it running thru there again? THank you
Prashant M
Level 3:
  • Master 2,278 Answers
  • Posted on Dec 07, 2009
Prashant M
Master
Level 3:
Answers
2278
Questions
Helped
978468
Points
6246
You will need to check the settings of the router .
You said that when you connect the computer to the modem it works, now connect the modem and computer to the router and open the router set up page .
Check the settings of the router.
You may need to set up the router again.
Click Here for step by step info
1helpful
I want to connect Hughes HT1100 modem (satelital) to my Zyxel wireless router (P-660HW T1 v2). I need the configuration for the Zyxel
Type 192.168.1.1 or 192.168.0.1 if the first one doesn't work. You can to Zycel's website to get information on the various settings that will apply to your application.
How to plug a WNR1000 Wireless Router into a Hughes net HN7000S modem
It should connect with an Ethernet cable. Looks like a phone cable but is twice as wide with 8 pins instead of 4. Plug one end into the modem's Ethernet output port and plug the other end into the router's single WAN/Internet input port.
2answers
I am running hughes net satelite internet on a hughes HN 9000 modem and trying to setup and configure my linksys E3000 wireless router for two hp laptops on direct ethernet connection to our desktop,...
Are you trying to connect the laptops via wireless? Is that where you are seeing 75 mbps? I am assuming you are, and 75 mbps is really not how fast your internet connection is. Rather, that is how fast you are transferring data from your laptop to the wireless router and back. Generally speaking, this should be a way faster connection than your internet is running at. Chances are your internet connection speed is 10 to 20 mbps, which is good and fast.
It is easy to get the two confused, but basically a wireless connection of 75 mbps is an uber fast connection to your wireless router, and only if your actual internet connection was faster than that 75 mbps would you see any slowness due to that.
Wireless N routers are capable of delivering up to 100 mbps connection speeds, but again that is only from your device to the router. The router then goes to your modem and out through the internet. Chances are that connection is not 100 mbps because of interference, which can be walls, other wireless devices, etc.
One way to test your actual internet connection speed is to go to www.speedtest.net and click on one of the links on the map. This will tell you how many mbps you get to the internet.
Lose internet connection (hughes net) when hooking up router
I would contact your hughes net, that is a satelite provider. That is a total different system, than dsl or cable. Hughes net should be able to walk you through the setup.
2answers
Wndr 3300 net gear router wont work with hn 9000 hughes net modem
I went to the Hughes web site to check out the modem. They say it is also a router. I think you will have to disable the router abilities of your WNDR 3300 Net Gear Router.
Get into the Netgear setup by loging on to it.In its WAN setup select Static IP Address and set the Static IP Address to the same as the hughes modem, except for the last number which should be about 50 greater. IE: Hughes 192.168.12.1 and Netgear 192.168.12.55.
In the DHCP setup, disable the DHCP Server
In the Wireless setup, Give your network a name is SSID. You should also set up security to keep others off you internet connection with a WEP key.
I hope this helps.
Rx not glowing
The HN7700 apears to be the hughes satelite modem. Make sure the dish is still aimed properly. Strong winds can move it off line. Make sure the cable is attached to the LNB unit. Best way to do that, is to remove and re-attach it. My guess is the dish alignment os out. If this is not a satelite modem then you can ignor this solution.
NetWave Base G4 router "goes to sleep"
well one thing if your router uses the same IP address as your hughes net then they will interfere with each other. hook your router to your pc and leave the hughes modem out of the equation then go to command prompt on your pc and type in ipconfig that will tell you what ip address your router is using that way you can get into the settings of the router and change whatever you need to change.....I would just set it back to default and make sure the ip address is not 192.168.0.1 because that is the dynamic ip for hughes
2answers
Does a satellite internet network require a special wireless router or will a DSL wireless router work? (Huges satellite)
They will provide you connection on their satallite modem. You can use any wireless router of your choice with the same.
Regards
Sammy
Broadband router
You need to plug your blue cable back into your laptop and the other end needs to go into your hughes modem, or you could leave the end that is plugged into your hughes modem and put the end that is now in the desktop modem into your laptop instead. To have the desktop on the internet you have to remove the end in the laptop and put it into the desktop modem.
The blue cable is spare unless you have any extra sockets that will accommodate it in your hughes modem and have both laptop and desktop connected to it.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
