All 4 hand sets have "connecting..." on the scren and no singnal. Phone line is OK. I have old phone and it works fine.
Please, advise
Thanks
Step 1: Press and hold FIND HANDSET on the main telephone base for 10 seconds.
Step 2: When the IN USE light starts to flash, release the FIND HANDSET button.
Step 3: Press and release FIND HANDSET again. The IN USE light will turn off and in a few seconds, all handsets will be de-registered.
Step 4: All handsets will show NOT REGISTERED.
To register a handset (register 1 handset at a time):
Step 1: Place the handset in the base unit or a charger that is connected to a power outlet. If PRESS FIND HNDST 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and place in base or charger again.
Step 2: On the telephone base, press and hold FIND HANDSET for four seconds. Release FIND HANDSET once the IN USE light comes on.
After
a while the handset will emit a series of tones, the newly registered
handset will be assigned the lowest extension number not previously
assigned to another system handset (1-4) when successfully registered.
Repeat Steps 1 and 2 if the handset does not successfully register to
the telephone base within two minutes.
I have the same problem. Base rings, handset tells me it's 'connecting...' and I can only answer it once the answer machine picks up. Two of the other handsets just will not work at all sometimes. Phones are charged. Tried solution but handsets do not read de-registered. Would change batteries but don't want to spend money on four phones if that will not solve problem.
land line is working vtech phones say no line
I have a 4 unit Panasonic Kshatriyas-t7030 that suddenly stopped working. It is not the phone line because other phones tried work well. What could be the cause? Thanks
