SOURCE: 1974 60hp johnson outboard won't run on full throttle.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
SOURCE: 30 hp johnson outboard motor trys to start. It
Pull the flywheel off and file or replace the points. if you replace the points set them at .020
SOURCE: need exploded view of 14 hp johnson outboard motor fuel pump
Need year mode?. But you can go to this website and get all you need. Don't worry I'm not a salesman. I just use this site for my own business. www.crowleymarine.com. click on parts catalog then follow directions.
Hi terrykorthui, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Is it a ficht model?
