Question about Sony KDS-R60XBR1 60" Projection HDTV
How do I fix my Sony KDSR60XBR1 bad white color?
How do I fix my TV's white color, because adjusting colors results in an off white color and TV does not show white color clearly?
  • tharris1875 Dec 06, 2009
    I added dark color as suggested, but white football jerseys and the numbers on the field do not look to be off white.
    I added dark color as suggested, but white football jerseys and the numbers on the field look to be off white. Sorry about bad information before this.
    Guru:
  • 1,738 Answers
Add some dark color to your adjustment.
Posted on Dec 06, 2009
6ya staff
SOURCE:
Sony wega KSD-R60XBR1 green screen that can not be adjusted no matter what input is used or adjustment through onscreen tv options. how do i knw if it is the color wheel, light engine, or just a bulb
It is light engine problem in your Sony KDS-R60XBR2 lcd rear projection tv.
This tv does not have any color wheel because of its light engine technology.
Lamp is just light source that provides bright white light to light engine and its working properly.
Light engine will be replaced to fix green screen problem.
If you tv model is other than above mentioned, let me know to revise this answer.
Hope these info will help you.
Thanks.
Nov 17, 2010 | Sony KDS-R60XBR2 Television
Sony wega kdsr60xbr1 Its picture is a greenish
If this is the model I am thinking of, don't bother fixing it. Call up sony and they will should offer you an new sony bravia lcd tv. You can either get the free one or upgrade from the free one to a bigger one. I guess that there is some recall with the light engine and sony is giving out this offer. This happened to my grandma to her 42" grand wega. The ending result was that she got a 46" 120hz sony bravia tv for, if I remember right, $250. I hope that this helps. Good luck and happy new years!!!
Jan 02, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
I just replaced the bulb in my Sony 55'' Grand Wega. the picture looked fantastic the first day. turned on the TV the next day and everything that should have a ''white color'' looked pink. the blues...
Please adjust TINT control of Video Settings in Menu that will adjust color tone of TV. I do not think this problem is related with Lamp because TV screen does not have any color blobs or spots.
Above solution is for Sony KDF-55WF655 model TV, if your model number is different, let me know.
Thanks.
Nov 29, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Show movies in black and white no color
unit is in a progresive mode. need to turn back to interlaced.
Jun 01, 2009 | Sony DVP-NS575P DVD Player
Picture is now black and white
 First, confirm that the source is actually in color - try another channel or input device.
Next, check the settings of the color control - it may have accidentally been turned down. If your TV has some kind of automatic picture mode, try turning if off and adjusting the color control. Try adjusting fine tuning if you have such a control and the problem is with a broadcast or cable
 transmission.
At this point with a confirmed color signal source, there is a problem with the chroma circuitry.
Note that to the average person, the obvious question becomes: is my color picture tube bad? The answer is a definitive NO. It is virtually impossible for a defective CRT to cause a total loss of color. A defective CRT can cause a lack of a primary color - R, G, or, B or a short between two colors which will mess up the color but is not likely to result in a black and white picture.
Some possibilities in no particular order:
  1. Weak signal or defect in tuner/IF causing loss of signal strength.
  2. Coler killer set too high (internal control) if it has one.
  3. Defective part around the chroma chip/circuit. Faulty color oscillator.
  4. Bad connections in area of chroma chip/circuit.
  5. Defective chroma chip (don't suspect this first just because it is probably very expensive).
A service manual or Sams', DMM, and scope will help greatly in attempting to troubleshoot this unless it is an obvious bad connection. Try prodding the main board around the chroma chip with an insulated tool to see if you can make the color come and go.
I had one set where a $.02 resistor decided to open up causing just this problem - perfect BW picture, no color. Another had a coil with a broken wire.
May 08, 2009 | JVC AV-36S33 36" TV
Bad color
Turn the color level all the way down and see if you have a good black and white picture. If your screen isnt black and white it should have a predominate tint to it. then turn the screen control for that color down to achieve the best black and white picture. then adjust your color level that should help.
Jun 13, 2008 | Mitsubishi WS-48311 48" Rear Projection...
Color convergance
The green hue (I had it too) is a result of the optical block failing.
Sony has extended their warranty (regardless of the purchase date). see link
http://esupport.sony.com/US/perl/news-item.pl?mdl=KDSR60XBR1&news_id=185
Apr 24, 2008 | Sony KDSR50XBR1 50" Projection HDTV
Bad color on sony kv-36fs16
Possible bad CRT....check video out on C board,video drivers on
A board.........................T.
Dec 23, 2007 | Sony KV-36FS16 36" TV
Bad picture color. red LED blinks 5 times. Replace picture tube?
Definitely bad picture tube==not worth fixing......T.
Oct 11, 2007 | Sony KV-36FS16 36" TV
Color
Most likely a bad CRT,not worth fixing......T.
Oct 10, 2007 | Sony KV-36FS16 36" TV
Sony KDS-R60XBR1 60" Projection HDTV Logo
257 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
