Sharp R-316FS Microwave Oven Logo
Posted on Jan 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Jenn-Air Microwave M169B 11 years old.
When I press start the microwave works for a few seconds and turns off. Getting worse by the day. (Yesterday, it would run for 20 seconds, now only 2 or so.) I've reset power at the circuit breaker, checked the door interlocks, etc. Everything appears fine. Ideas? All door latches and sensors seem fine.
  • PickyRicky Jan 17, 2008
    Update: I know now that its the START/STOP membrane switch that's the issue. Scotch packaging tape over that section of the panel, over a separator will do the trick as it did on a washing machine a few years ago for me.
William Miller
Level 3:
  • Sharp Master 9,179 Answers
  • Posted on Jan 21, 2008
William Miller
Sharp Master
Level 3:
Answers
9179
Questions
Helped
4478257
Points
21747
You should be able to get a replacement keypad, and that's not a hard job for a DIYer.
If you're interested, post your correct brand and model and I'll give you a more specific suggestion.
(Your post subject says Jenn-Air M169B put it's posted under Sharp R-316FS so I'm not sure which you have).
If it's a Jenn-Air, you can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
You can usually find Sharp exploded views by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
You can order Sharp parts from there or from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Jenn air microwave quits working after 11-13 seconds of heating
open circuit switch when power reaches this switch it will shut down as switch is us
I have a Jenn air microwave and it just quit the other day while I was warming water. It is about 7 yr old. Is it worth fixing?
I recommend replacing it, as you said it is 7 years old and prices have dropped on the new microwave ovens making it more attractive to buy. The repairs with parts and labor will approach the cost of a new one.
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
1helpful
Jenn-Air JMC7000 Microwave stop working
I have the same unit and age the JMC7000 everything appeared normal on the display and countdown etc...But it would not heat,I trouble shooted the problem and discovered it was a faulty door switch I replaced it and it works like new again.I ordered the part from www.repairclinic.com it's an easy fix.and costs a few bucks...
1helpful
2answers
Jenn-Air JMC7000 Microwave Stopped working
So it's dead? (No display, no inside lights, no beeps?)
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Top Sharp Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
