My set is 2+ years old and started malfunctioning 2 weeks ago when when power was applied... green lite switches to flashing red after an instant display of video. Unit was shut down then re-powered 2-3l times , (sometimes only once) video then came back on for the entire evening. Now when power is applied, green lite flashes (15-20X), then turns to flashing red (4 X) cycle), no matter how many times I re-start. Please advise.....Thanks
I have the answer for the fan issue on the KDSR50XBR1!!!!!
Ok, I think I have the answer for the BIG FAN failure. I recently did a
similar fix on the spindle of an xbox 360 and it is identicle. Ok, this
is an EXTREMELY EASY FIX...
Open the back of the tv, locate the large fan (on the lower left on the back of the set.) unscrew the screen and remove the fan.
Once the fan is removed, you will see the side with the model number and the other side is totally open.
On the open side, pull...
The fan will come off, into your hand, it is only held by magnets...
You will notice a spindle on the fan and the other side has the magnets
and the hole where the spindle came from (this is the fan motor).
Clean both the spindle and the hole (motor) with a q-tip. The hole is
smaller than the q-tip, but do the best you can to remove the old
lubricant.
Get a bit of WD40 and lubricate the spindle and spray a touch in the hole.
Put them together, reconnect your fan, test it on startup and thank me...lol...
HOPE THIS HELPS!!!! IT WORKS, TRUST ME...
What do you think? Spread the word, lets save some folks from spending needlessly...
I get the same problem (4 flashing red lights).
I done some internet troubleshooting and narrowed it down to an overheated power circuit card/fan issue.
It turns out one of the fans is failing and will not rotate at the appropriate speed to cool the power circuit card, this will kick out the 4 flashing lights from the diagnostics.
In lieu of replacing the fans I have a temporary solution:
For my TV (kdsr50xbr1) the fan in question is located on the far left side (facing the rear). You will see a grill on the back of the TV showing you where the fan is located.
First, get a can of compressed air and blow it into every fan. This will clear away a lot of dust and help the fans move easier.
There is one blower type fan located inside the TV, remove the back panel and look for a tall yellow circuit card just to the left off the center of the TV. Behind that card is a blower (stands upright looks like a tube). Blow air into that blower, you will see a lot of dust come through the duct and out where the large fan in the center is located.
Put everything back together. and provided the fans aren't too far gone the TV should be working again.
Also, if the issue comes back, try this:
When you turn on the TV, shoot a short squirt of compressed air into the fan (Far left facing the rear). This will give it a kick start and bring it up to speed.
It is important to note that the compressed air cans do contain a liquid and as such are not compatible with electronics when they are plugged in. Try your hardest to keep the can upright and not allow the liquid to squirt out where it shouldn't. If it does it will evaporate in a few seconds.
Ok, relatively long post, to summarize:
1. Open back of TV, blow compressed air into every fan to clean them.
2. Blow air into whichever fan is causing problem if it happens again.
3. Keep the can upright if the TV is still plugged in. Don't sue me if you fry your TV.
4. If this doesn't work (has for me) replace fans
The red light flashing 4 times is for the internal fan malfunctioning
Replacing the projection lamp was never so easy......I am curious to know if there is any data on the expected life (in operating hours) of the XL-5100 lamp
I have the same problem and a Sony Tech came out and said that it is a FAN issue. Says I need to replace all 4 fans. $150 in parts and $400 in labor. I want to try and tackle it myself to save the $$$. Would love some advise if anyone on here can provide it. I know that Sony sells the service manual for $45. Anyone know where I can downlaod a copy?
I've got the 60" version of this TV.
Had the blob problem. Got that fixed.
Had the lamp burn out. Had to replace that.
Now after about 4 minutes of TV watching, the screen goes blank, the green light flashes about 50 times and 1-2 minutes later the screen comes back on.
Thanks in advance for any help.
I've tried everything listed ,here, and still have the same issue. Does anyone happen to have the part numbers for the fans in question?
