Sony Cyber-Shot DSC-S500 Digital Camera Logo
Posted on Dec 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Describe how to turn on the flash - Sony Cyber-Shot DSC-S500 Digital Camera
Anonymous
Level 3:
President:
  • Master 1,901 Answers
  • Posted on Dec 05, 2009
Anonymous
Master
Level 3:
President:
Answers
1901
Questions
5
Helped
761150
Points
6406
On the control button (large button on the back) at the top is a symbol that looks like a lightning bolt with an arrow tip. This is also the UP arrow. When you press it continually, the flash options will be noted by symbols.
No indicator - Auto
Lightning bolt - Flash forced on
Lightning bolt followed by SL - Slow Synchronized flash
Lightning bolt with the circle and line through it - Flash Forced off
You can refer to the manual for your camera at:
http://www.docs.sony.com/release/DSCS500.pdf
Use of the control button is on Page 17.
Thanks for using Fixya.
95 chrysler new yorker, car starts for 2 to 3 seconds and stalls, headlights flash off and on and turning signals flash, how do i fix it?
I owned a LHS and 94 New yorker both cars did this, have the door locks checked for a loose wire for the alarm system, something is telling the security system there is a breach, you must lock the doors, shut the door and then open the car door by unlocking it with the key or it will continue to do this. Mine had loose wires and the door lock would not sense the key so I used the passenger door in the same way I described above. IT will NOT Start and run if this is an issue until the alarm is reset by doing as I described. Good luck BTW both cars suffered from failing transmissions, very weak trans in these cars.
Sharp tv turns off
Open and look at power supply board for capacitors which are "balooning" or deformed in any way. These look like cylindars on the board. These tend to dry out and make what you are describing occur. Replacing them usually fixes about 80% of the problem you are describing. Those parts run about $0.25 to $0.75 each.. well worth trying, right?
12helpful
How do i turn off my flash on my panasonic dmc-fh27?
Touch [MENU] to bring up the menu. Touch [REC] to enter the recording menu. Touch [FLASH] to enter the flash menu. To turn the flash off, select "Forced Flash: OFF" (lightning bolt in a circle with a slash through it).
The flash menu is described on page 66 of the advanced manual.
1helpful
How to install a Nikon SB-700 AF Speedlight Flash for Nikon Digital SLR Cameras
Basically, you put batteries into the flash, put it into the flash mount on the top of the camera, turn everything on, select a flash mode, and start shooting.
The flash comes with a detailed manual describing its operation. There is a section in the camera manual describing the various flash modes. The SB-700 is fully compatible with the Nikon iCLS system, which includes the D3100.
Since you asked a general question, I can only give you a general answer. If you have any specific questions, please feel free to ask them.
FE 20 turn off flash
Look for the flash button (looks like a lightning bolt) to cycle through the flash options. Flash options can be limited in AUTO Shoot mode.
The manual describes how to use the Flash on page 19 of the manual.
You can download the manual here http://www.olympusamerica.com/files/oima_cckb/FE-360_X-875_C-570_FE-20_X-15_C-25_Instruction_Manual_EN.pdf
2006 pt cruiser on drivers side rear turn signal
The turn signals flash depends on each and every bulb working correctly. When one bulb fails, you will notice a change in the flash frequency, as you describe.
Replace or repair the bulb that is not working, and you should be good to go.
Doc
Red flash, then tv turns off
red CRT defective. I have one brand new if you want to fix it.
My flash stopped "flashing"
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
