SOURCE: Can anyone tell me where to get the rubber tires
Bandsaw tires are sized according to the wheel diameter, so for an older machine like yours you'll need to check that first.
Then you'll have many options available, simply by googling bandsaw tires.
To get them on, heat in warm water before stretching.
Here's one link to get you started: Carter
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
SOURCE: I need the rubber tires for a Craftsman 103.24300
the part number is 36815 at a price of 9.49 each and you will have to call your local Sears to order them. Let me know if you need more assistance and if I have helped you would you please rate this response accordingly. Thank you
SOURCE: I need to find replacements for the rubber on the
the part number you need is 817911 and they list for 12.99 each and you can find them at searspartsdirect.com and they just roll on making sure the notches line up. If I have helped you with your request would you please rate this response accordingly. thank you
SOURCE: hi i have a craftman bench 10 inch bandsaw that has blade drif
The problem could be one of two things. The tires could be worn or glazed with rosin. Try cleaning the tires with mineral spirits to remove the build-up. The other possibility is that the pulleys are out of alignment. To check this, put a straight edge across the face of the lower pulley and see if squares with the upper pulley, if it doesn't, loosen the set screw on the upper pulley and adjust accordingly
