It's possible that the DVD you are trying to play was manufactured for a different region than the one your DVD player is set to. DVD players are designed to play DVDs that are encoded for a specific region or regions. For example, a DVD player that is set to Region 1 will only play DVDs that are encoded for Region 1.
You can check the region code of your DVD player by looking at the back of the player or consulting the user manual. You can also check the region code of the DVD you are trying to play by looking at the back of the DVD case or consulting the information that came with the DVD.
If the region code of your DVD player does not match the region code of the DVD you are trying to play, you will see an error message like the one you described. One solution is to try setting your DVD player to a different region and trying to play the DVD again. However, keep in mind that most DVD players can only be set to a particular region a limited number of times, and once the limit has been reached, the region code can no longer be changed.
It's also worth noting that some DVDs are encoded for multiple regions and will play on any DVD player, regardless of the region code. If you have a DVD that is encoded for multiple regions and it is not playing on your DVD player, there may be another issue at play.
probably you are trying to play a disc that is not zone free or you need a code for your player to make it zone free. you may be playing a zone 2 disc ( PAL) on a machine that only takes zone 1 (NTSC) or vica-versa.
To change the Region code on your player, open Control Panel - System - Hardware - Device manager, and click on DVD/CD ROM drives, then right click on the DVD drive and click Properties then click on DVD Region. You can enter a new region and it also shows you how many changes have been made. NOTE you can make only 4 changes and the player will lock permanently on the 4th change. If you want to play DVD from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk. The best solution to make the player region free is to install a piece of software that allows you to play DVDs from any region. There are several available on the Internet but my favourite is DVD-Region Free From: - www.dvdidle.com/dvd-region-free.htm
no solution but i have exactly the same problem - the system has suddenly stopped playing any dvds at all including ones it has previously played - i get no sound or picture just a circle with a + sign in the middle on the dvd digital display
if its saying wrong region. then either your player or disk is incompatable. region 1 ntsc ( USA ) Region 2 ( UK ) et,c. check your players region coding is compatable for your country, and that you are also playing a dvd with the same region coding as the player. alternatively is to try and find a region free or multi-region solution.
Mike @ Compurepair.
Turn on power. Open lid. Enter 9735 with the remote and press 'enter', you can now choose between regions on the screen. Select the desired region unlock and press 'enter'. This works well!
