E-Machines eMachines Desktop PC Logo
Anonymous Posted on Dec 04, 2009
I am buying a used eMachines T5082 with an Intel 3.0 HT 533Mhs FSB Prosessor, but an 800 Mhz Bus on the Motherboard. I wish to upgrade to an Intel 600 series 3.8 Ghz 800Mhz FSB CPU although i do not know which one to use & matching Memory. I was told to use DDR2 SDRAM 800 Mhz PC2 6400 for the Memory. Could you tell me if this will work alright & which Pentium 4 600 series 3.8Hhz with Hyper threading technology to use ? I will be using my Vista Home Premium O/S in this T5082. I have seached everywhere but can't seem to find this info. I truely appreciate your help on this matter. Will-
Anonymous
Level 3:
  • Master 4,889 Answers
  • Posted on Dec 05, 2009
Anonymous
Master
Level 3:
Answers
4889
Questions
8
Helped
1512822
Points
14106
Intel 570J has a clock speed of 3.8Hz and has 800Mhz FSB. It supports DDR SD and DDr2 SD RAM modules. You can get the full specs from here
http://www1.uk.shopping.com/xPO-INTEL-P4-570J-3-80GHz-800FSB-1MB-SKT775-Retail-BX80547PG3800EJSL82U
1helpful
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
5helpful
Need specifications for Intel PM-865G1 mobo
Specifications
CPU
• Supports Intel® P4 Northwood/Prescott/P4 Extreme Edition processors.(PCB v1.1 only)
• FSB 400(Northwood only)/533/800MHz
• Supports up 3.2GHz and higher speed
Memory Speed/CPU FSB Support Matrix
FSB\Memory clock DDR266 DDR333 DDR400 800 MHz YES YES* YES 533 MHz YES YES NO 400 MHz YES NO NO
• Intel® 865G Chipset
- Supports 800/533/400MHz Intel NetBurst micro-architecture bus.
- Integrated graphic controller.
- Supports PC2100/PC2700 /PC3200 memory.
- Supports AGP 8X/4X at 0.8V (AGP 3.0) or 4X at 1.5V (not support 3.3V) interface.
• Intel® ICH5 Chipset
- AC'97 2.3 interface
- 8 USB 2.0/1.1 ports
- 2 channel Ultra ATA/100 Bus Master IDE controller
- SMBus 2.0 support
- 2 serial ATA Host Controllers
- Integrated LAN controller
• Support 100(Northwood only)/133/200MHz
• Support 400(Northwood only)/533/800MHz Intel NetBurst micro-architecture bus.
• Supports two 64-bit wide DDR data channels.
• Available bandwidth up to 3.2GB/s(DDR 400) for single-channel
mode and 6.4GB/s(DDR 400) for dual-channel mode.
• Supports four unbuffered DIMM of 2.5 Volt DDR SDRAM.
• Supports up to 4GB memory size without ECC.
• One AGP slot supports 8x/4x at 0.8V (AGP 3.0) or 4x at 1.5V (3.3V is not supported).
• Three PCI 2.2 32-bit Master PCI Bus slots.
- Supports 3.3v/5v PCI bus Interface.
• One CNR slot
• Dual Ultra DMA 66/100 IDE controllers integrated in ICH5
- Supports PIO, Bus Master operation modes.
- Can connect up to four Ultra ATA drives.
• Serial ATA/150 controller integrated in ICH5
- Up to 150MB/sec transfer speeds.
- Can connect up to two Serial ATA drives.
• AC'97 link controller integrated in ICH5
• 6 channels software audio codec C-Media 9739A
- Compliance with AC97 v2.2 Spec.
- Meet PC2001 audio performance requirement.
- Can support SPDIF Out via 3-pin SPDIF bracket only.
• Intel 82562EZ
- Integrated 10/100 Ethernet MAC and PHY in one chip
- Supports 10Mb/s and 100Mb/s auto-negotiation operation
- Compliant with PCI v2.2, and LAN on Motherboard (LOM) standard
2helpful
Can I upgrade my CPU to an Intel Core 2 duo 1.7
You are basically limited to what was optional on the model. So you can only upgrade to one of the following cpus:
Intel Pentium M 745 (1.8-GHz) with 400-MHz front
side bus (FSB)
Intel Pentium M 735 (1.7-GHz) with 400-MHz FSB
Intel Pentium M 725 (1.6-GHz) with 400-MHz FSB
Intel Pentium M 710 TJ85 (1.4-GHz) with 400-MHz FSB;
operates at a lower temperature than other processors
Intel Celeron M 340 (1.5-GHz) with 400-MHz FSB
Intel Celeron M 330 (1.4-GHz) with 400-MHz FSB
And you are limted to 2gb of ram max on this model.
1helpful
I could use a diagram of the mother board for a Pentium 4 2.4 Ghz processor. I picked one up second hand to replace my old processor
If your processor 2.4 Ghz HT you need socket 478 motherboard,System bus 800.without HT you need 533 FSB Motherboard.You can buy easily.Where you live? I do not know.China are available made 478 PIN mother board.
2helpful
3answers
Is it possible to upgrade to a faster processor on a hpn pavallion dv1000
here is a list of processors supported on that machine
side bus (FSB)
I bought a pentium 4 3.0 ghz 800 mhz & my
The motherboard chipset of the Dell Dimension 2300 Desktop PC, will not support a processor with an 800MHz Front Side Bus frequency rate.
Only Intel Pentium 4's that use a Socket 478, 1.75 Volts, and a maximum of a 400MHz FSB.
The Intel Pentium 4 HT 3.0GHz processor has an 800MHz FSB, (As you have already stated), and uses 1.475 to 1.55 Volts.
The motherboard chipset for that Dell Dimension 2300, is an Intel 845GL.
This list on Wikipedia, shows you parameters the Intel 845GL chipset supports,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_Chipsets
Not a good outcome, sorry. Just stating the facts.
2helpful
2answers
Replacement for INTEL Desktop board D865GLC
I've found an Asus P4SD i865GV online:
http://www.geeks.com/details.asp?invtid=ASUS-P4SD-NOAGP-R&cat=MBB
It seems to have the same CPU socket, FSB and RAM types, and the chipset is almost the same model. I'd say this would work.
If you can't get that, just make sure to get a motherboard with the following qualities:
Front side bus (FSB): 800, 533, and 400 MHz
RAM type: Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
CPU socket: 478
P4 or dual core
You can update to a dual core since your using a 775 socket just make sure the dual core is also 775 socket which there are quite a few. and of course make sure its intel. and the FSB is 800 mhz
1helpful
2answers
Front side bus speed on CPU Celeron D331 2.66GHz 256K LGA775
According to the spec's this motherboard has FSB speeds of 800+3.
Here is a link to the page I found stating the spec's for you.
Spec's
I have read reports of this motherboard having problems though. You might need to get a little better motherboard.
Reviews
I hope this helps, and thanks for using FixYa,
Eric
2helpful
Upgrading Processor & Graphics card
The Intel® 845G chipset is optimized for the Intel® Pentium® 4 processor supporting Hyper-Threading (HT) Technology†. It is designed with the high performance 533/400 MHz system bus and integrated high-speed USB 2.0.
Max Cpu
Pentium 4 2.8ghz with a 400mhz FSB and
Pentium 4 2.63ghz with a 533mhz fsb
pay close attention when getting your cpu if it has a 533 front side bus and is faster than 2.63 then the actual cpu speed will end up slower (you will see something like 2.1ghz) if it comes on due to multiplier limitations
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
