When switch washer on it makes a whirring sound, stops then nothing. After about 5 mins, the top green light and the 65 degree light flashe on and off. help!
For saftey the lid lock and lid down switch must be activated before the machine can advance to the next cycle. This has been the sequence for all top loaders..
Check the switch for the lid it is likely defective.
The motor coupling is about to completly go out on you and then it will not spin at all. This is common on these machines. the repair should be under $100.00. The motor brake may also be dragging.
I'm and owner and will try to help. Are you handy and do you want to try a DIY fix? From the wash times is sounds like the washer is agitating the wash load (tumblers are rotating the wash basket load) is that correct? If so see if the machine will complete a Spin Only cycle with no clothes in the wash basket. Set the Spinsetting to Spin/Hang dry seting and start the cycle.It should take about 10 min complete.Does the Spin Only cycle complete with no clothes in the wash basket? Some handy links if you are going to DIY.........Service Manual for reference.
Story could be lengthly so in brief, check to see if drain pump is not blocked and if door latch is functioning correctly.(use a multimeter if you can). If it all measures out as good, then your control is faulty. Does the water fill up to the correct level when you start the cycle? Does the motor hum when trying to run. If so check the capacitor.
if you can get the front plate off you will probably notice that the drum stabilizer roller has either fallen off or is damaged. This part is replaceable and should be no more than 20 bucks.
sounds like the timer needs a little assistance to get "over the hump". perhaps many cam switches must be switched at his point of cam rotation.
if machine is getting old, then attempt to lubricate the electric motor that turns the timer mechanism. also lube the shaft bushings for the timer cam plate as well if possible.
