1. SINCE NO ONE HAS A FIX FOR THIS ISSUE. I HAVE ONE THAT WORKS BUT THE ISSUE SHOULD AND MUST BE DONE BY THE MANAFACTURS OF BOTH PRODUCTS. THE FIX GOES LIKE THIS A COST YOU NOTHING IF YOU HAVE A CELL PHONE: WITH MOST CELL PHONES YOU GET A COMBINATION EAR PIECE AND MIC ALL ON A SMALL BLACK CABLE THAT PLUGS INTO YOU CELL PHONE FOR HANDS FREE SERVICE. ALL YOU HAVE TO DO IS TAKE THE PART OF THE CABLE THAT HAS THE MIKE AND ALSO HAS A BLACK PLASTIC PART THAT YOU WOULD USE TO HOLD THE MIKE ON YOUR SHIRT AND WITH THAT PLASTIC HOLDER CLAMP THE MIC AT THE VERY END OF THE ARM THAT HAS THE TURTLE BEACH MIC JUST BEFORE THE SOFT FOAM COVER WITH THE MIC FACING IN TOWARDS YOUR MOUTH. PLUG IN THE VERY SMALL EAR PIECE INTO YOUR EAR JUST LIKE YOU WHERE GOING TO USE IF WITH YOUR CELL PHONE. PLACE THE HEAD SET FROM TURTLE BEACH ON LIKE YOU NORMALY WOULD AND PLUG IN THE END OF THE CELL PHONE MIC CABLE INTO THE SLOT ON YOUR TURBO FIRE TWO CONTROLER AND AWAY YOU GO. THE EAR PIECE IS SO SMALL THAT YOU WILL NOT EVEN FEEL IT IN YOUR EAR, THIS WAY YOU GET ALL OF THE GREAT SOUNDS FROM THE HEAD SET AND CAN ADJUST ITS VOLUME BUT YOU CAN ALSO CHAT THRU THE MIKE AT THE SAME TIME. IT WORKS GREAT AND DOES SOLVE THE ISSUE IN A RUBEGOBLDERG SORT OF A WAY. WE STILL NEED IT CORRECTED FROM THE FACTORY. IF YOU ARE PLAYING TWO WORLDS TWO THEN YOU KNOW ME AS DEEP RESERVE WHERE I USED THIS COMBINATION WHEN IN THE MARSHLAND LEVELING UP.
