The charger died shortly after it was used the first time - My guess is that the board is faulty because nothing shorted and the unit is clean but the light doesn't go on.
Does anyone know where I can get it repaired in Durban?
It is a 21.6V PF21.6VH
Powaforce battery charger.
ps. email me the specs of your charger the input, output, the current (MA) and the voltage 14.v or 21v to [email protected]
How can you say its nothing shorted?did you check the parts and its all good?maybe you are looking for a sign of burned on the board but you cant see errors and you can find nothing if there is a shorted or defected electronic parts,by means of just looking it unless you are going to use a multi-tester.
if you still didn't check the parts,try to test the diodes,transistors & resistors..these 3 electronics parts are commonly have the risk of malfunctioning.
also,get attention to the charger wire/conductors if there is a cut inside it or the fuse might be opened.
