have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
a. On the taskbar double-click the Camera Assistant Software icon , or from the Windows® Start menu, point to All Programs, Camera Assistant Software, and then click Camera Assistant Software. The Camera Assistant Toolbar location briefly displays on the desktop.
b. On the Camera Assistant Toolbar, click the Start Camera button and click on the icons on the software.
NOTE: If you are not hearing the audio portion of the video you created, try the following: Verify that you do not have the audio capture muted. An X appears on the Mute button when Mute is selected.
Click the Functions button, and then click the Audio tab. In the Audio Output section, verify that the Digital Mic is selected from the Audio Device drop down list, and then click Apply. In the Audio Volume section, use the slider bar to increase the volume level. Verify that the notebook
