1. First, back up your critical files (don't forget your Outlook .PST archive) to optical discs, an external drive, or online storage.
2. Examine data and power connections (SATA or IDE, depending on the drive), a power adapter cable (with some SATA drives), and screws.
3. Mount and connect the drive
When installing SATA drives, jumper settings usually aren't an issue. That's not true of IDE, where a jumper indicates whether a drive is a primary ("master") or secondary ("slave") drive. Check its documentation for the proper setting
4. Configure the BIOS, Next, boot into your PC's BIOS-setup utility to verify that it recognizes the new drive and positions it correctly in the drive hierarchy. (Check your PC's startup screen to determine which key launches the utility.) If the utility lets you select the boot order, give your intended boot drive priority over any other hard drive
Save changes and exit the utility. Your PC will reboot
5. Partition and format your hard drive, Click Start > Control Panel > Administrative Tools > Computer Management, and choose Disk Management from the tree at left. Your new drive should appear, with a black bar indicating it isn't partitioned. Right-click the bar, and choose New Partition to launch the New Partition wizard. Click Next, and check that Primary Partition is selected; click Next again, to the Specify Partition Size screen (don't change the partition size in the "Partition size in MB" field); and click Next to advance to another screen, on which "Assign the following drive letter" should be selected. Click Next yet again (to the Format Partition screen), and ensure that "Format this partition with the following settings" is selected and that the "File system" drop-down reads "NTFS." Click Next a final time, hit Finish, and formatting begins.
Good Luck Delgado...
thanks for the hint and advice.. ;)
I have the same problem, and I don't see a solution provided here. My factory drive was SATA, and so is the new one I replaced it with; if the factory drive didn't show up as removable, the new one shouldn't either. there has to be a way to edit this policy in the registry editor; does anyone know how?
Chad
