1988 sedan deville cadillac runs good until the lights are turned on then it starts acting like its going to die
Sounds like the battery is weak or the alternator isn't providing enough amps to keep the engine running and power the lights at the same time.
Testimonial: "thanks , it sounds logical. Should I replace the battery? The guy who owned it before me just replaced the alternator."
The best way to test the alternator is to crank your engine and leave it running. Pop the hood and disconnect the negative battery cable. If the engine dies with the cable disconnected, it's the alternator. If it keeps running, the alternator is fine. Just be mindful of the belts and fans. If you have a dc voltage meter, that's the best way to check your battery. Should be around 12-13.6 volts DC.
