Samsung Gleam (SCH-u700) Cellular Phone Logo
Posted on Dec 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Want to erase all personal data prior to recycling
Want to erase all personal data on it prior to recycling it: Phone #, Address Book, any other personal info on a sim card OR built-in memory
Anonymous
Level 2:
New Friend:
  • Expert 124 Answers
  • Posted on Dec 04, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
124
Questions
0
Helped
25640
Points
343
You need to go to options, reset then hit master reset. It will then require you to enter your password, which will be 1234 or 0000 or 00000 if you havent changed it.
How do you import contacts
When you install Outlook 2010, it automatically converts the Personal Address Book that you used in an earlier version of Microsoft Outlook. Outlook 2010 then adds the converted data to your Outlook 2010 Contacts folder.
If Outlook 2010 does not automatically convert your Personal Address Book, you can import your Personal Address Book to Outlook 2010. To do this, follow these steps:
  1. Start Outlook 2010.
  2. Click the File menu.
  3. Click Open, and then click Import. The Import and Export Wizard opens.
  4. Click Import from another program or file, and then click Next.
  5. Click Personal Address Book, and then click Next.
  6. Click Browse, locate the Personal Address Book that you want to import, and then click OK.
    Note Earlier versions of Outlook assign a .pab file name extension to a Personal Address Book. By default, Outlook stores the Personal Address Book in the following folder: C:\Documents and Settings\username\Local Settings\Application Data\Microsoft\Outlook
  7. Click Next.
  8. Click Finish to import the Personal Address Book.
I need to know how to unblock a phone number in address book?
Unlock code for Samsung Sync SGH-A707
If you have forgot your phone lock code and you want to unlock it....then all you have to do is to type this code at your normal dial screen: #7465625*2877#
(Note:This code will reset your phone to default settings and all your data that is stored on your phones memory will be erased,so store your important data on your memory card before you type this code.)
I can send but not receive texts on lg GC900
try to do factory setting default code is 1234 or 0000, or to hard reset try 2945#*# and select factory settings, but before try all this make backup to avoid loose your data of device.
This will solve your problem.
How do I delete all personal info. from system prior to recycling? (I purchased a new Uniden & want to recycle old one)
There should be a option somewhere in the menu of the phone that will allow you to reset/delete all data on the phone. If there is not then sadly your going to have to go through and delete everything manually.
1helpful
How do I reset and erase all personalized data from the phone, before recycling it?
Click 1. Settings 2. Initial Setup 3. Master Reset menu 4. Master Clear
It will wipe all information you have entered into the phone. "Master Clear" will wipe out your phone book, pictures and all the other files you have saved.
If this helps, please rate. Thank you
1helpful
Why is there a check mark next to name under contact? LG Dare
You must have touched it accidentally. That feature is so you can select multiple contacts in your address book to send a text, video, or picture message to, or erase from your address book....so be careful! Side note....If you see a check mark next to the contact name in the "sent messages" folder, it means that person is also on Verizon, and the message you sent was received/delivered to their phone.
2helpful
7answers
How to delet all the contacts from iphone
If you are using itunes for windows and have synced your contacts with Windows address books and your contact list is now filles with all of your contacts email addresses, here is a quick way to delete your address book at once.
create 2 empty text files on your desktop and rename them to
AddressBookimages.sqlitedb
and
AddressBook.sqlitedb
copy/overwrite these empty files into " /var/root/Library/AddressBook" folder, using "Ibrickr"
this will empty your contacts list, since all contacts are stored in those two files.
* This wont take effect untill you restart your phone
3helpful
2answers
How to restore address book and photos after doing a master reset
sry, a master reset completely and permanetly erased all data, and i have not seen any device or sequence that can restore that info. Sry, and
GOOD LUCK gettin everyones # again!!
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
