Sharp XR-1X Multimedia Projector Logo
Posted on Dec 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sharp xr-1x is stuck in standby mode. just
Sharp xr-1x is stuck in standby mode. just installed a new bulb and cannot get it to reset the timer. Turn on bulb then locks in standby mode
  • vivanola Dec 04, 2009
    turns out it was one of the fans that was jammed. Once I got it spinning the projector quit shutting itself off
jasbo
Level 3:
  • Master 2,239 Answers
  • Posted on Dec 04, 2009
jasbo
Master
Level 3:
Answers
2239
Questions
Helped
992055
Points
5072
Hold down the menu, enter, and down arrow buttons then press the on button. this will reset the lamp timer. if it's not working, you may have a controller issue (main board).
  • Pati Porleifsson
    Pati Porleifsson Apr 23, 2022
    Hold down the menu button on the remote and OK button and down arrow under the OK button and at last the on button, 4 buttons ?
1helpful
Projector sharp XR-H325SA indicating lamp I replace tha new lamp but still indicating ineed to reset lamp timer but how?
hi,
for resetting the lamp hour do the following
1. Plug the power cord into the AC socket of the projector.
2. While simultaneously holding down MENU/HELP, ENTER and DOWN ARROW button on the projector, press STANDBY/ON on the projector.
3. "LAMP 0000H" is displayed, indicating that the lamp timer is reset.
ok
I have a Sharp XR-10X-XL projector, i have replaced the bulb but it still will not go on. The Stand by light and the bulb light are both on constant red, I have checked both the heat sensor and the fuse on...
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
1helpful
I have replaced the lamp on my sharp xr-10x L. I cannot get the bulb to turn on I have lights so there is power but the lamp is not on.
You must reset the lamp timer. Check the manual or sharp website for instruction how to reset the timer after changing the lamp
3helpful
Projector does not start, standby lamp and lamp indicator still remains on after replacing new lamp
Have you reset the timer?
• While simultaneously holding down
MENU/HELP, ENTER and R on the projector,
• “LAMP 0000H” is displayed,
Sharp XR-1S Projector, no picture, lamp light flashing..... help!
if it's under 1 year old, it's still under warranty, so send it in and get it fixed for free.
3helpful
New bulb in now wont work - no power - wont turn on to reset lamp
first, make sure you have the correct lamp. the lamp for the xr-10x-l looks like the xr-10x, but the plugs are different (common mistake). make sure you have the AN-XR10L2/1, not the AN-XR10LP/1. to reset the lamp timer (with the projector plugged in but off), hold down the enter, down arrow, and menu buttons and press the power.
6helpful
XR-10x bulb timer has timed out. How do I reset the projector?
you need to reset the lamp timer see http://www.ercservice.com/PDF/Lamp-Sharp-XR10-XR20.pdf
Stuck in standby mode
The light bulb must be seated in perfectly, otherwise it won't see a connection and won't come on. take the bulb out, and make sure the connections don't have any dirt on it. Anything that can obstruct a connection. Give that a try.
No power at all
You may have to reset the Bulb Life Timer. When the power is turned on, you simultaneously press the "right arrow", the "down arrow" and the "menu" buttons, then press the "standby/on" button, it should zero out the Bulb Life Timer and it should come on.
Curt
11helpful
5answers
Sharp xg-h400u projector Lamp timer reset.
plug the projector in. Do not turn it on.
hold the menu, enter, and down keys at the same time....
Press On
The map will turn on and the screen should display Lamp 0000H
Pg 54 of the xr-10x manual -- http://www.sharpusa.com/files/pro_man_PGMB56X_66X_XGMB50XL_XR11XCL_XR10XL_XR10SL.pdf
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
