Bissell 9200 Upright Vacuum Logo
Posted on Dec 04, 2009
Bissell 9200 upright carpet cleaner does not spray water. Could it be the pump or solenoid, or both?
  • Anonymous May 11, 2010
    does the hose spray?
Anonymous
Level 1:
Scholar:
New Friend:
  • Contributor 33 Answers
  • Posted on Jan 24, 2010
Anonymous
Contributor
Level 1:
Scholar:
New Friend:
Answers
33
Questions
0
Helped
15281
Points
48
It could be the pump. You can open it up and see if the pump is working by taking the pump input tube and inserting it into a bowl of water. Pull the trigger and see if water is leaving at the pump output.
However, ensure you have the simpler things covered first:
Ensure you have water in tank and solution (or water in solution tank). When you start the vacuum up, the pump starts to prime itself. If you have air in the system, it takes a little longer to prime. Allow the vacuum to run for 1 minute before attempting to pull the trigger. Then pull the trigger.
If this doesn't work, you'll need to open the unit up and check the hoses for any clogs, and next test the pump to see if it is functioning.
3helpful
Bissell proheat 2x carpet cleaner 9200 How do i
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
teyet
2helpful
Have a model 9200 that is not dispensing fluid,
heatman101
bnv,nm
2helpful
My bissell Proheat 2X Carpet cleaner will not dispense water
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
11helpful
Bissell 9200 Proheat 2x carpet cleaner
cleaner will not start
yes, I plugged it in!
29helpful
3answers
Schematic parts diagram for bissell proheat 9200 carpet cleaner
Hi, just go to amazon here: Amazon com bissell proheat carpet cleaner parts and you can find every needed parts. I hope this was helpful. Cheers
Top Bissell Vacuums Experts
Mike Cairns
Mike Cairns
Renee Knafel-Bullock
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
