Mast reset is different from unlocking code..Unlocking code will release the network lock..And master reset , reset your mobile if you forget your security code.. If you want to use your mobile with other network means, you have to unlock it..It can be done through codes..If you need get the code from http://www.prounlocking.com/ .It helps to unlock your Samsung M3510 beat easily.
Using the codes you can unlock your mobile because its safe for your mobile........ Get the unlock code for your samsung sgh_t35 model mobile from this site Classicunlocking.com , here it gives the easy methods for getting the mobile unlocked.........
you could get master reset code free of cost from your service provider .. or else You can also visit http://www.unlock-zone.com/ and get unlock code at affordable cost.
T-Mobile branded phones are locked to T-Mobile which is true of almost all carriers. You have to buy an unlocked phone in order to get it to work like you were anticipating.
PUK stands for personal Unlock code. This is not a lock code on the Phone. This code is a lock on the sim. When you enter the PIN number wrong thrice the sim gets blocked. PUK code is needed to unblock the sim. To get the PUK you need to contact your sim Provider (Network Operator. PUK -2 come when the PUK -1 is also entrered wrong. you need to cotact your Netopwrk operator.
Try this, I unlocked mine after forgetting my password; it should work, since it's samsung universal!!!
Just take in mind it will RESET the whole phone, all your contacts, txt's and photos or music will be deleted!! but if you want to unlock it here you go!!
*TAKE the sim card OUT *Turn the phone on *Enter : *2767*3855# = Full Reset (Caution every stored data will be deleted.)
You have to Contact Customer Care for your PUK (PIN Unlocking Key) & then follow these steps:
NOTE: Before you can unlock your phone, you must have your PUK.To unlock your phone, perform the following steps:
1.
Type the PUK and select OK.
2.
Type a PIN of your choice and select OK.
3.
When the Confirm New PIN message appears, re-type the PIN code.
4.
Select OK.
