Computers & Internet Logo
Posted on Dec 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wont read disc
Wont read game or dvd or music disc..hear it spinning round in drive then just stops..
Nanny
Level 3:
Genius:
  • Sony Master 2,351 Answers
  • Posted on Jan 20, 2020
Nanny
Sony Master
Level 3:
Genius:
Answers
2351
Questions
0
Helped
988779
Points
7262
You can check on this tutorial to troubleshoot the problem with different solutions:
Why is My DVD Drive Not Reading DVDs
Zhareese
Level 2:
Habit-Forming:
  • Expert 177 Answers
  • Posted on Dec 03, 2009
Zhareese
Expert
Level 2:
Habit-Forming:
Answers
177
Questions
0
Helped
38153
Points
492
Hello there... Sony seems a choosy brand so it looks like your disc is not recognized by it. Check also your disc for scratches or you just need to clean your disc first before you can use it. Try it. If this doesn't help, try inserting your disc to other CD-ROM. See if your disc is okay. Hope this helps...
Ai-ai :)
Xbox wont read any of our games, but the games will read on friends. We can listen to music or use our microsoft points to watch movies.
Sounds like an issue with the optical drive. I would suggest trying a different type of disc in the drive ( I think they can play music CD's as well as DVD discs). You might just need a replacement drive for it.
2answers
Ps3 want read any disc what do i ned to do
If console will not read any discs (dvd cd or bluray)
If you hear it spinning
1 Either the lasers is bad (replace laser)
2 spinner is bad
3 Or drive board is bad cant be controller chip (send into sony or replace chip)
If you do not hear it spinning
drive may be off track not completly loading the discs
5helpful
2answers
Disc drive not reading disc
To best respond to your question, let me review what happens when the unit tries to read the disc. First a check is made to see if a disc is present at all. If a disc is detected, the next step is to spin it up. You should be able to hear this happen. OInce the disc is spinning, the initial track (closest to the center of the disc) is read. If the read fails, a number of times, the mesasge about not reading the disc is presented. This failure can be caused by a number of different things:
1) The lens is dirty
2) The disc is not spining at the correct speed
3) The disc did not get up to speed fast enough
4) The loading sequence did not complete.
5) Defective optics
I will list the typical solution for each of the possibilities above:
1) Clean the lens using a cotton swab and alcohol and try again.
2) Replace the optics assembly (motor is not a replacement part.)
3) Same as #2
4) Replace the loading belt located under the tray. (get help with this as it is a bit tricky to do without mis-timing the loading sequence.)
5) Replace the optics asembly.
To confirm that the optics are actually defective, try playing a music CD. If a music CD will play but a game or DVD will not and you have cleaned the lens, then the optics are likely to be defective. A game or DVD requires a different (higher) level of laser light to function than a CD.
Hope this helps,
Dan
3answers
Will not read any disc's
Its because the dvd scanner is scratched or broken
Xbox doesnt spin or read disc
dvd drive is bad if the spinning is intermittent. DVD drive is going to need replaced. You can usually find them on Ebay for pretty cheap.
My disc wont spin in my drive
hi i have had and fixed this problem pemenently!!
u need to take apart your xbox and remove the dvd drive:
then you need to crack open the dvd drive
once open if you look at the top part of the drive that would hold your game/disc youl notice that it is infact two pieces that are magnetinc and they will be stuck together
what you need to do is seperate them
then take the smaller piece and locate where it has come from
this is the centre on the dvd drive like on the pc where you would push the game on to
you need to super glue the small piece back into positon
reassemble let dry and it will now be working..
i no its hard to understanmd what ive written hear but this is a really easy fix...
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
