My hp vs19 computer screen was working fine when i shut down and now it won't power on at all.
  • 319 Answers
HPw1907 monitor on "built up" computer. Processor is AMD Sempron 2800+(800)S754, Video card is Navidia, Albatron GF FX5500. Operating software is Windows XP home, SP 3.
Factory brightness setting is much too high. Each time that I restart the computer after shut down, I must reset the brightness setting. Immediately after startup, brightness is OK; after a few seconds, the monitor goes into auto adjustment, and goes back to factory setting and I have to reset.
I will appreciate any help that is provided.
Posted on Dec 03, 2009
6ya staff
SOURCE:
Hp dx2200 computer won't power off
If your HP computer refuses to power down, this means that there are still programs open that Windows can't close. Normally when you select the "Shut Down" button from your "Start" menu, Windows closes all open programs, then closes itself, and your basic input/output system (BIOS) turns off all of your hardware. If Windows can't close all open programs, your computer won't be able to power off. This means that you must close these programs yourself.
Right-click on the window of an open program on your Windows taskbar (Bottom of Screen) Click "Close Window." Windows manually closes the program. If a window appears on-screen indicating that Windows cannot get the program to close, click the "Force Close" button in this window to have Windows force the program to shut down. Repeat "Step 1" for any additional programs that are open on your computer. Click "Start." Click "Shut Down." Hope this helps.
Dec 10, 2012 | Computers & Internet
Describe your vs19 (Silver) 19"
You did all the correct diagnostics and proved that the monitor is faulty. Take to a local service centre for repair.
Feb 22, 2018 | HP vs19 (Silver) 19" LCD Monitor
HP vs19 monitor does not turn on.
You may have to inspect the inside of the monitor. You may have to dry it out from the inside and look for burned component which may be caused by a short due to the moisture.
Aug 15, 2009 | HP vs19 (Silver) 19" LCD Monitor
My HP vs19 will not power on
I suggest you might try another power outlet, otherwise maybe the "fuse" in your screen might be dead, also try to go to the store that sold it to you to see the warranty it might still be on it because some manufacturers give sometime 3+ years of warranty. Also check with you manifacturer
Thanks
Apr 04, 2009 | HP vs19 (Silver) 19" LCD Monitor
Higher resolution
I f resolution is increased your display will not suit hence either add an additional Nvidia Graphics card which supports the resolution and try should work fine.
Apr 02, 2009 | HP vs19 (Silver) 19" LCD Monitor
My HP vs 19 desktop monitor is on, but the screen is blank. It flashes on for less than a second when I turn the monitor off, and then back on -- but then goes blank. What is the solution?
If you are handy at fixing things.
Here is a link of how to fix your monitor. I had the same problem, and found this link, followed the instructions and it cost me $5.13
to fix my HP vs19 LCD monitor, and its still working great.
HP vs19 LCD Monitor fix
http://boredprojects.blogspot.com/2008/06/hp-vs19d-fix.html
Don't drag out your soldering gun these are too high wattage and will melt the board. Use a 40 to 25 watt soldering iron.
Dec 13, 2008 | HP vs19 (Silver) 19" LCD Monitor
Power Light Blinking & Black Screen
A blinking blue light indiactes that your power-inverter board is not putting out what it should. It needs an overhaul which may be a simple as changing out the capacitors on the boards.
It could go beyong that to transistors or even a bad bulb.
It will have to be opened up to do that.
A picture may show visual signs of damage. If you can take one and email it to me , I'll take a look.
Fran
Oct 18, 2008 | HP vs19 (Silver) 19" LCD Monitor
Going to Sleep Displayed
I turned on my computer and the monitor displayed this message on the screen "going to sleep no input received". I checked the power cord and unplugged it, nothing. No lights are flashing or beeping sounds. The CPU is working just fine, anyone have any idea what to do
Aug 02, 2008 | HP vs19 (Silver) 19" LCD Monitor
Fan7601 vf48 Hp lcd monitor
hello stephentunga,
sorry mate, try hp service center near your place.
ty.
May 10, 2008 | HP vs19 (Silver) 19" LCD Monitor
Power
Check the power cable first. Check your monitor switch is working properly or check your smps in your monitor.
Feb 19, 2008 | HP vs19 19" LCD Monitor
62 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
