Mitel 5020 Logo
Posted on Dec 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mitel 5020 holding
How do we changing the call holding facility on our mitel 5020 ip phone?
Anonymous
Level 2:
Sergeant:
  • Expert 378 Answers
  • Posted on May 01, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
378
Questions
0
Helped
186380
Points
794
What is the problem with this? Are you referring to the Music on Hold? If so, what do you have for MOH? What phone system do you have? The 3300 ICP can have the music embedded into the programming. All other Mitel systems have to use an external source.
You should contact your vendor for assistance.
If you're referring to the hold time, you should contact your vendor to change it.
  • Anonymous May 01, 2011
    Music on hold or timer... either way contact your system admin or vendor.
Problem with Mitel 5212 IP Phone
Need to login to. The phone system and change it back.
Hi, I need to set the IP configuration on my MITEL 5212 IP Phone manually, but I do not know how to do it. I guess that there is a sequence of key to press, any help will be appreciated.
Press and hold the up arrow key while booting the phone. Configure telephone - YES, Network Parameters - yes, then NO until you see Change. Set the appropriate information, IP address, default gateway, ICP IP address, TFTP server address, etc.
You should be warned that this gains nothing except making another device on the network that requires deliberate management.
- Mark
4helpful
How do you do a factory reset on the Mitel 5324 IP Phone ?
Unplug the power from the phone. Hold down the Down Arrow key, and power it back on while holding the key. You will get an option to default the phone to factory settings.
We are unable to turn a ringer on, for when the general number rings, on one Mitel 5020 IP Phone, and we would like to make it so another phone doesn't have to hear the ring on the general number ring.
This is set on the buttons for the phone from within the system programming. Individual buttons can be set to NO Ring, Ring, Ring Continuous, Delay Ring, or Delay Ring Continuous.
Continuous meaning that even if you are on the phone, it will ring audibly on your phone. If it's not set to continuous, it will only give a blip.
You should contact your vendor for assistance in setting this up.
How do you reset the time on the mitel 5220 ip phones
The time is set within the phone system, not on the telephone. Contact your vendor for this change.
1helpful
2answers
How do I change the time in a mitel 5212 IP phone?
Contact your system admin or vendor. The time is set in the phone system, not in the phone.
I want to change the time on the face of my 5020 mitel phone. I have a user manual but it does not address this issue. Please help! It's an hour and 10 minutes ahead and it's hard to work thinking it's 5pm...
Login to phone system or you can setup the time thru the console or a sub attendent phone. If the class of service has that option. It is a little different for the different Mitel phone systems.
Dec 21, 2009 • Mitel 5020
I want to change the time on my 5020 ip phone
Hello!
The manual for your phone can be found at the Mitel website, here:
http://edocs.mitel.com/UG/EN/31_5020_NA_R4.0.pdf
Oct 26, 2009 • Mitel 5020
Divert calls on 5207 IP phone
you will need to get the call fowarding always code from your system administrator.
Nov 04, 2008 • Mitel 5020
Top Mitel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
