My bissell vaccum will pick up stuff but all the sudden has started making a very loud noise that is not normal, whats the problem , how do i fix it?
Hi mandilyn,
underneath your vaccum there is a brush that rotates round maybe stuck with bit`s of carpet turned round your brush just remove it by cutting with something sharp that should free your brush and your vaccum should work fine.
Could be plugged, check the hose and at the bottom by the brush roll, the inlet maybe clogged. Also check the filter under neath the dirt tank. There are filters above the dirt container, clean those out. If after that it is still loud, then maybe the motor fan or bearins are bad and will have to be replaced, part #2031214 sells for around $55.
I have the same problem.. with my vacuum... I did find that it was clogged. I cleaned everything... all filters... hoses... I mean everything... but its still about twice as loud... I found what almost looks like a safety of some sort inside... but haven't pulled everything apart to see what it might be.... but it is whats leaking... any suggestions?
bissell loud sounds
