Click on start menu and then click on run or in the search box, type services.msc and hit enter
it will open the services window, locate the service named as print spooler in it ,
Right click on print spooler and select restart, restart it atleast 6-7 times, then check the printing queue....
I have this problem at least once a month, and this is the first time I have found a solution that works first go. Thank you.
SOURCE: job in queue
Let me exaplin the cause why the jobs get stuck in queue: When ever we try to print there is a windows service called print spooler that manages the print jobs in queue. We can clear the jobs in queue by just disconnecting the usb cable and restarting the print spooler service. Here are the steps to restart the print spooler : 1.Click on start 2.Then click on Run 3.In the Run box type " net stop spooler " Then press enter Note: Type the text with out inverted cotes in the run box this will stop the print spooler service Next we have to restart the print spooler 1.Click on start 2.Then click on Run 3In the Run box type " net start spooler " and press enter Once done reconnect the usb cable and check for the jobs in queue. If there are no jobs in queue you can set the print directly settings to avoid this issue in future. Just open the printer and faxes folder and right click on the printer icon and select properties and then click on the advance tab and under it select the option print directly to printer and click on apply and Ok to save the settings. Once done try to print this should resolve the issue.. Wish u success..
SOURCE: deleted print job stuck in queue
You can always restart the computer, that will "unstick" a print job that gets stuck deleting.
SOURCE: print job cancel wont work
if the print job doesn't get deleted after a restart of your computer, do the following:
Click on start -> Run, then enter: services.msc
Click OK to open the Services windows. Locate the entry "Print Spooler" in the Services list. Click it and choose "Stop" and "Restart".
Your print job should then be deleted.
If my answer was helpful to you, please leave a positive feedback.
