Sharp AR-5320 Black and White Copier Logo
Posted on Dec 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CODE ERREUR L4 DANS UNE PHOTOCOPIEUR SHARP 5316
Tareq Bin Mostaq Mostaq
Level 3:
President:
  • Sharp Master 1,449 Answers
  • Posted on Dec 02, 2009
Sharp Master
Level 3:
President:
Answers
1449
Questions
31
Helped
614482
Points
3628
L4 mean this copier main motor is not move or run.
First time, Open your copier back cover and check any gear is broken,solve it .Or clean all mechanical which one jam.If you are not a technician so you call a service Engineer who are qualified this Brand.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 17, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1028
Points
Solution codage H5-01 copieur SHARP ARM 450
Sharp MX-3640N A3 Color Laser Multifunction Printer. Error service code: C1-14.
Question edited for full 'make model (what it is)'.
Error Codes > Sharp > MX3610N > Code C1-14 - PrintCopy .info
https://printcopy.info > code=C1-14
Code: C1-14 · Description: Main charger trouble (Color) · Causes: The main charger unit (CMY) is not installed properly. There is an abnormality in the main ...
SOLVED: Error code C1-14 - Sharp MX5001N - Fixya
https://www.fixya.com > ... > Sharp
Apr 9, 2019 - Code. C1-14 · Description. Main charger trouble (Color) · Causes. The main charger unit (CMY) is not installed properly. There is an abnormality ...
How to remove error code C1-14 For Sharp MX-2501N - Fixya
Sept 5, 2019
Questions & Answers for: sharp error code c1 14 - Fixya
Nov 16, 2019
SOLVED: Sharp mx 3100n C1-14 error code - Fixya
Dec 12, 2020
Error code C1-14 - Sharp Mx-2310u Color Copy/print/scan
Apr 8, 2013
More results from www.fixya.com Missing: 3640 ‎' Must include: 3640
Sharp MX-2630 Error C1-14 - Copytechnet
https://www.copytechnet.com > ... > Sharp
Apr 27, 2019 - Error Code Sharp MX-2630 Error C1-14. If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to ...
Sharp MX2640 error C1-14
Jun 20, 2017
Error Code C1-14 on MX3100N
Jul 23, 2011
MX-6240, 7040 (Polaris) with error code C1-0X ...
Jul 17, 2015
More results from www.copytechnet.com Missing: 3640 ‎' Must include: 3640
Codes erreur SHARP - Sharp Photocopieur
https://www.photocopieur-sharp.com > codes-erreur-sh...
C1. C1 10 MAIN CHARGER TROUBLE (BK). C1 14 MAIN CHARGER TROUBLE (COLOR). C4. C4 00 PTC TROUBLE. E7. E7 01 MFP IMAGE DATA ERROR. E7 03 HDD TROUBLE.
Sharp MX-2310U, MX-3111U (SERV.MAN68) Technical Bulletin
https://servlib.com > Sharp > Printer
MX-2310U, MX-3111U (serv.man68). CCE-1425 MODIFICATION OF TROUBLE CODE C1-10 or C1-14 DUE TO DEFECTIVE MC PWB - Sharp Copying Equipment Technical Bulletin ...
J'ai une erreur code h4-00 avec ma copieur sharp MX 5001N couleur
https://translate.google.com
http://onenaijablog.com/2015/06/how-to-fix-call-for-service-h4-00/
Comment r?gler le «Call for Service H4-00» sur mon copieur Sharp
Si vous avez un scanner num?rique tel que le Sharp AR-M207, vous saurez qu'un jour, vous rencontrerez peut-?tre de petits probl?mes comme «appeler le service H4-00 ou L4-11». Appeler un technicien peut s'av?rer inutile ou co?teux, vous pouvez donc le faire vous-m?me.
Si vous photocopiez ou num?risez un document et que l'erreur «Call for Service H4-00» se produit, le red?marrage de votre appareil est la seule option possible. Et ci-dessous vous explique comment red?marrer votre copieur.
Pas
Nous devrons passer en mode simulation en appuyant sur # * C * 14 (HARSH - STAR - C - STAR - 14), puis en appuyant deux fois sur le bouton de copie. La machine red?marre et le code d'erreur cesse de s'afficher.
Vous avez red?marr? votre ordinateur avec succ?s...
Remarque: vous devrez disposer d'un doigt rapide pour pouvoir passer en mode simulation.
https://www.helpowl.com/q/Sharp/MXM310/Troubleshooting/clear-h400-error/1027388
D?faut de la thermistance de la lampe de chauffage principale, ou
D?faillance de la lampe du chauffage principal, ou
D?faillance du thermostat principal, ou
?chec du contr?le PWB.
https://www.photocopieur-sharp.com/codes-erreur-sharp
H4 00 FUSING SECTION LOW TEMPERATURE TROUBLE (TH_UM_AD2)
H4 00 SECTION FUSIONNEMENT TROUBLE BASSE TEMPERATURE (TH_UM_AD2)
Code erreur u 2 sharp ar 5316
memory error, pls press the copy key to see what the sub code is...if 04 appears, eeprom problem failure....try to cancel using simulation 16.
1helpful
2answers
Ma photocopieur shar 5516 marque un message d'erreur H4
H4 error indicates the fuser is faulty and should be replaced.
4helpful
3answers
MON PHOTOCOPIEUR AFFICHE LE CODE ERREUR L 6 SUR LE PHOTOCOPIEUR SHARP AR-205 DIJITAL QUE DOIS-JE FAIRE
L6 = Polygon Motor Lock Detection
Polygon motors are not serviceable items.
Try switching the machine off/on. If the code doesn't clear then you will need to get the motor replaced. Quite often the motor will have made a screeching or rattling noise before it fails.
Hope this helps
Bonsoir, Sans arrêt, une fenêtre apparaît.
recommandé d'exécuter malwarebytes ou AdAware. peut-être un virus?
18helpful
3answers
I have a sharp photocopier AR-5316 flashing error code is h4 how to reset this code and solve the problem
i have a sharp photocopier AR-5316 flashing error code is E7 how to reset this code and solve the problem
Ma photocopieuse affiche H4
salut ! le code H4 c'est une erreur qui vient du fuser ( la ou le papier passe et les rouleaux deviennent chaud)
Il faudrait checker la lampe de chauffage et voir si elle est intacte,
la deuxieme possibilite est le fuse de prevention de haute chaleur, (thermofuse)
L'une des deux est votre probleme. Salut, et Bonne Anne.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
