What Message you are Getting? If you are getting " Searching For Base " Message, the handset is trying to find its paired base unit. Sometimes you need to sit the handset into the base unit for it to register itself back with the base then there is nothing you can key into the handset to fix this.If you have tried all this and it still can't see the base unit then either the base unit isn't the paired match for the handset or the base unit or handset has a fault. Take both ends in for repair.
Have you got wireless broadband? The wireless modems can interfere with 2.4Ghz phones, try switching off the modem to confirm.
Otherwise,
To register a handset Place the handset in its charger (connected to a power outlet A / C Mains.)
check the phone line is a good connection too.Press FIND HNDST for 4 SECONDS if ON BASE
does not appear on the screen of the phone after a few seconds,
lift up handset and place in the charger again. and try it again please.Failing that,
On the main telephone base,Press and hold INT/FIND HANDSET key for four seconds.Release INT/FIND HANDSET key when IN USE light is on.
The After about 10 seconds the handset will emit a tone and the handset will be assigned the lowest extension number not previously assigned to another system (1-4) when successfully registered.
Repeat steps 1 and 2 if handset is not registered within two minutes.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
You get Error!! on your display due to the following reasons:
1) The handset’s registration has failed. If you use the handset near to some other cordless base station or if you use it near some electrical appliances, you get this error,
To solve this error, Move the handset and base unit away from all electrical appliances or other base unit and try again.
2) Another reason by which you get Error!! on your display is if another handset user tried to send phonebook items to you but there was an error. Have the other handset user re-send the items to you.
To resend the item from the other unit,
Press Menu-> # 2
Press UP and DOWN and select the desired handset and press SEND,
When you hear a long BEEP press OFF..
The above two things are the main reason for getting ERROR!! message, any of the solution should solve your issue,
Please accept this solution if it works, else leave me comment we will solve your issue.
Rnj VinodKumar
Clear off any clear plastic protector on the contacts and the new base.
Let it charge for 2+ hours.
1 Handset:
Press {MENU}.
2 Scroll to “Initial setting” by
pressing {V} or {^}, then press {>}.
3 Scroll to “Registration” by pressing
4 On base unit: assign NEW headset number. SAVE the setting
5 Handset:
Press {OK}, then wait until the handset
beeps.
Place the new headset onto the original base to link.
Registration is complete.
On step 4 you need to assign the number to the new head set.
It's all depending on the base unit.
This new headset has to be within
BASIC BASE unit (1 headset) I hope you do not have this base. This base is not expandable.
Press and hold {LOCATOR/
INTERCOM} until the CHARGE
indicator flashes.
Deluxe (2 headset max per system)
Press and hold the locator/handset
button that corresponds to the handset
you want to re-register ({LOCATOR/
INTERCOM 1} or {LOCATOR/
INTERCOM 2}) until the registering
handset number (H1 or H2) is
displayed.
Most current (3 headset max per system)
Press {SELECT} repeatedly until the
desired extension number (H1, H2,
or H3) is displayed on the base unit,
then press and hold {CALL}.
Please post the model number printed on the bottom of the base unit on reply.
The last digit of the base model number indicate the max number of headset can be sync.
I have a new (3rd) handset for my Panasonic KX-TG5632 phone. The handset is charged and I followed the instructions for registering it with the base. The handset displayed "registering handset" after I pushed all the buttons as instructed but then displayed "Error!!" and did not register. I tried this twice with the same result.
The base system I have allows up to handsets. The number on the bottom of the handset I just bought is KX-TGA542M. My other 2 handsets are KX-TGA560M. When I ordered this model number online I received the 542M hanset. It looks exactly the same except two of the buttons have different labels. Could this be the problem? Handset incompatibility?
The base is not near any appliances other than the refrigerator. The base unit is attached to the wall and it is not practical to move it.
I have read the reasons for the Error!! display in the manual but I don not believe these are the reasons the handset won't register.
Do you have any other ideas?
Yes, I read these explanations in the manual, too. However my base is not near any appliances other than the refrigerator and no one tried to page from another handset. I do not believe either of these are the reason the handset won't register. Do you have any other ideas besides what is in the manual?
