Shut it off and unplug it from power. Let it sit for a day before trying to connect again.
Make sure you've rebooted your computer before trying it again.
Hard drives fail sometimes but so do the enclosures to - so you may still have the data.
If it does work - backup everything immediately.
If it's clicking - that's the sound of death for hds.
I had a somewhat similar problem - and found the cause NOT to be the drive, but rather the power cord/supply to the drive.
Here is what I did....as I worked through the list of reasons the drive may not be showing, I'd surmised the problem was not computer / connection based, but rather with the drive itself - which had a faint clicking noise as it cycled (generally a bad sign it seems).
However, what I also noticed was that a similar noise (though a beep vs. click) was coming from the power cord/supply to the malfunctioning drive. Fortunately, I had a different power cord on hand from another drive I have - and when I used that, it worked just fine.
And, last but not least - when I tried using that power supply on the other different drive - that drive did not work either (also making the faint clicking noise).
So bottom line, it was the power supply - NOT the drive which was really good news, and enabled me to access/retrieve all my data....and not have to pay upwards of $2k to retrieve data.
Hope this too helps!!!
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
hope this helps you
