Ovens Logo
Anonymous Posted on Dec 02, 2009
Bottom coil does not heat. Top coil for broiling works ok
Anonymous
Level 2:
  • Expert 74 Answers
  • Posted on Dec 02, 2009
Anonymous
Expert
Level 2:
Answers
74
Questions
0
Helped
18534
Points
229
Check your fuses - both on the oven and in your breaker box.
Most likely the bottom coil has quit. Replacement is usually quite easy.
With the power off - you remove the screws at the back of the coil and disconnect the power lines. Bring to appliance center and they can match size/shape.
What should the voltages across the elements in an oven be when using the different settings?
The heating element is either off or on and it should be 220. The issue you are having is the thermostat.
Mar 09, 2016 • GE Ovens
What would be the cause for top heating element to not work on bake but be ok on broil
Because it is a broil element. Only some models on some brands will BOTH heat during preheat ONLY. Otherwise only during broiling.
Broil is OK. On bake only bottom ignitor energizes but never gets gas, top igniitor does not energize.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 07, 2011 • Ovens
Hi there, We have a Fidigaire Gallery electric stove and the oven does not heat up. We press thej"Bake" button followed by the up arrow to set the tempurature but the oven will not heat up. The...
well... have a volt meter?
Are the bake and broil coils the same?
If so, you can swap them to see if the broiler element glows in the bake position... if so then the element is NFG... to proove that put the bake element in the broil position and fire up the briol function... it should not heat up...
Usually the MFG. intentionally makes the elements with a different offset, so you cannot mix them up...
that's what the meter is for... unplug the element, and put the probes in the socket.
You will be reading 220 Volts, so be XTRA careful... if no 220 then the Module that controls the relay to activate the element connector is not working correctly... so you have to sorts test both ways...
Just be careful...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
Mar 10, 2011 • Ovens
What could be the problem when i put the oven on broil every thing is ok the top element come on ,but when i put it on bake only the bottom comes on
Hello, W/D here.
That's the way it is supposed to work. The top element comes on only for broil, but not for bake, and the bottom element comes on for bake, but not for broil.
Best regards, --W/D--
We have a GE gas oven/stove top and the stove top is lighting as well as the broiler but we can not get the oven to heat up. What do you suggest we try?
i just moved and our stove in the new place doesnt bake things right. it seems that the top coil doesnt come on. its very difficult to bake anything. seems to come up to temp for pre heating, but only the bottom coil comes on. If you put it on broil, then the top coil gets hot. that works fine. tired of burning pizzas and biscuits. can anyone help with a cheap fix? dont have alot of cash.
Nov 12, 2009 • GE Ovens
3helpful
3answers
Thermador SC301T heating elements not working (top and bottom). elements look fine, oven turns on but elements stay cold.... any help would be appreciated. thanks, Tony
Its the thermal safety switch. When it trips - it cuts any power from reaching BOTH elements. Open the oven door - at the top wehere the oven latch is - remove the long black panel. In the middle - on the right is a small cylindrical switch...push down on the top - in the very center...it will rest the switch (like a circuit breaker) and then reassemble. Just did it on mine (2nd time) and it fired right up. Good luck
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Top Maytag Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
