Hi,it all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device. Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
You must enter the default Bluetooth pairing code, on your phone, when prompted. The code is 0000 (four zeros).
For your reference, the brand of a Bluetooth device has nothing to do with compatibility. Bluetooth Corporation licenses its technology to many other companies. Devices using Bluetooth technology must conform to the Bluetooth standards. So, a Motorola Bluetooth device will definitely pair with your LG phone, or any other brand of phone supporting Bluetooth device communication.
Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
