Gives error memory message when tries to change table set up
See if the cursor is checkered. If so, the calculator is out of memory.
You may have very little memory available and then wanted to create a table with a very small DeltaTbl (the table step). If the step is small, and the domain is large, very many points will have to be generated and that may make the calculator unable to comply for lack of RAM.
I suggest you free some Ram by clearing the lists, clearing the entries. To do so you press [2nd][MEM][3:Clear Entries] to clear entries, then press [2nd][MEM][4:ClrAllLists] to clear the lists.
Alternatively, you can just reset the Ram by pressing [2nd][MEM][7:Reset][1:All Ram][2:Reset][ENTER]. Then clear the Ram Cleared message and start again your table.
Hope it helps.
Thank you for using FixYa and for rating this solution.
