I have a Gemini home security system we no longer use. How do i disable it. The alarm goes off randomly at different hours such as 3am, 5am, 6pm. I tried bypassing the zones that seems to be the problem but the alarm still goes off. Is there a battery I can take out so it no longer works?
Yes the system has to be powered by something most times there is a security panel that all the wires run back to, their should be a transformer pluged into the wall somewhere or on the panel itself there should be a red and black wire that is hooked up to power in or 24v in, disconnect these wires or just take the fuse out if it has one. more than likely you will see the power supply. if not take a insulated srew driver and run it across the power contacts on the main board.
