Did you ever figure out what was causing your problem? Mine is doing the same thing. Did you ever figure out what was causing your problem? Mine is doing the same thing.
You can't post conmments that contain an email address.
You can just buy a new remote. Test it using the smartphone front camera trick. Or it is the television that has no signal, do a Power Reset. Pull the mains plug for 5 minutes. Press and hold the power button on the set for 1 minute. Plug back in. Also check the input leads on the back for whatever is supplying the signal, Cable, Satellite, OTA, then check the Source button on the remote.
Amazon.comhttps://www.amazon.com > product-reviews
Find helpful customer reviews and review ratings for Insignia LCD TV Remote Control - NS-RC01G-09 at Amazon.com. Read honest and unbiased product reviews ...
RemoteControls.comhttps://www.remotecontrols.com > product
Price: $9.99 FREE SHIPPING - ALL US REMOTES ... Shipping - We receive hundreds of orders a day at RemoteControls.com. We do our best to ship them the same day you ...
US$9.99
Amazon.comhttps://www.amazon.com > Replacement-INSIGNIA-N...
Buy Replacement Remote Control for INSIGNIA NS-RC01G-09 NS-P501Q-10A NS-L42Q-10A LED HDTV TV: Electronics - Amazon.com ? FREE DELIVERY possible on eligible ...
US$32.99 · In stock
Just FYI: I had a friend with an Insignia NS-32E570-A11 with a backlight problem, and it turned out to be one of the actual LEDs in the backlight array was burned out, causing some sort of over-voltage condition that made the backlight sometimes work, and sometimes just flicker for a moment at TV startup and then turn off. We took the panel apart and bypassed the one bad LED (it had a dark spot on it and failed continuity - you can test each LED with a continuity tester and see them light up!), and now the TV/backlight works! Be aware this is tricky bypassing the bad LED, as it is ultrasonically welded to the LED array strip (same technique used to make ICs), so you need to be a very good solderer to bypass it without it breaking the connection.
You need to check the 12 or 24v source coming from the power supply to the inverter board, that's the board usually to the left and rather tall. Get your meter set, then turn the set on and see what happens, if the voltage comes up and then shuts down, you'll need to pull the plug for the inverter and measure the voltage again. If it stays up you have a bad converter board, if not then it's in the power supply, that's good old fashion trouble shooting from there on.
It sounds like the red LED is signifying a fault. Check your manual (or ring the manufacturer's support line) to find out what the red LED means.
If it does in fact signify a fault, file a fault with the manufacturer and return it to them under warranty (if you still have it).
