To install sentry fireproof safe battery
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the sentry safe battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
SOURCE: Sentry S3807 safe-cannot open
locksmiths agree on how to install sentury safe batteries
reconnect the connector and put back the battery holder. Slide the cover back in place.
to install batteries, turn the electronic lock case to the right and remove.Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
SOURCE: The battery on my DSW3607
the battery pack is in the front where the combination is located. take off the front part, there is a screw at the bottom, batteries are behind.
