SOURCE: my sanyo vpc-c5 digital camera won't turn on
If you already tried a new battery, I would suggest cleaning the battery terminals with alcohols and a q-tip first and check for loose terminals. It may be a power switch which unfortunately can't be changed or fixed by the average user. If you want to trouble shoot further and feel you can do it yourself, I will send you links on repair. Otherwise it should be brought in to a reputable repair shop.
SOURCE: Sanyo VPC-HD1
Iris is not the cause of black screen.First confirm that shutter is opening as soon as you switch on camera.If shutter is not opened and you can't see live view on screen except black screen,then certainly there is problem with shutter assambly.
If shutter opens and you see black screen then there is problem with CCD.
SOURCE: Sanyo VPC-S7
if u want to take the date off all u need to do is to follow these steps
1)turn the camera on. then push the MENU button
2)once the menu screen has come up then go down to the words setup. then click OK to enter into the setup mode
3)Once your in the setup menu then go down to the words that say DATE STAMP then click the OK button and u will enter that
4)when in that it will have things like this YYYY MM DD
MM DD YYYY
DD MM YYYY
and lastly the word OFF will be there
scroll down to the word OFF and click the OK button. then u turn it of then bac on [if u want to test it out]
SOURCE: Help!! Sanyo VPC-E760 Digital Camera driver for Mac OSX
the driver is not separately available for Sanyo VPC-E760
SOURCE: Need users manualnfor sanyo VPC-T700 digital
Get the manual here >>>>>>>>
http://sanyoservice.com/pdf/images/VPC-T700.pdf
This manual will show as an on-line PDF, when its loaded up all you have to do is save it to your computer.
Regards
